    Non-uniform texture scaling in "Position Texture"
    3 Posts 2 Posters 670 Views 2 Watching
    • K Offline
      Klokl
      Hi, I'm on a Mac
      Is it possible to drag the green pin in Position Texture and have it scale the texture in a single dimension? Right now it scales up the entire texture in both directions.
      Or is there another way to do this non-uniform scaling? Thanks!
        Go to your material editor > In model, choose the texture in question and go to the Edit tab. There you can enter a non uniform size for the texture if you break the chain (i.e. it won't change both values uniformly)
        I know that the Mac material browser is a bit different (and I don't know it enough) so here two links about it
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=142367
        which refers to this link I believe
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=142374
        • K Offline
          Klokl
          That did it! Thank you very much
