    [Obsolete] TT_Lib (1.2.0) β€” 31 August 2010
    30 Posts 10 Posters 42.1k Views 10 Watching
      arqalexanderog
      I get this error apology
      Error loading file config.rb
      No such file to load - TT_Lib / loading file json.rbError config_ini.rb
      No such file to load - TT_Lib / loading file core.rbError inputbox.rb
      No such file to load - TT_Lib / loading file gui.rbError tt_selection_toys.rb
      No such file to load - TT_Lib / loading file core.rbError ui_manager.rb
      No such file to load - TT_Lib / loading file core.rbError window.rb
      I was not missing,
      I cooperation could you please remove me from this little problem
        How did you install it?
        You should have a TT_Lib file in your Plugins folder, and all those files you mention in that error you got should be inside that.
          arjunmax09
          @thomthom said:
          @arjunmax09 said:
          how can i use this plugin to manage my plugins?? πŸ˜’ I have no idea how to use this plugin...plz help
          You don't - it a shared library that some of my plugins use.
          I was advised by KXI that this plugin was formerly known as plugin manager and could be used to manage junk plugins. How can I do this?
          when you fail at something....you haven't really failed...you've found one way the thing will not work out
            You can't.
            It was previously intended to help manage plugins - but it was only for developers. It is only a library of reusable code.
            • dereiD Offline
              derei
              Could you update TT_Lib2, or make another library for your plugins, as now I have TT_Lib and TT_Lib2. I just made some cleaning in my Plugins and I deleted TT_Lib, because I assumed that is obsolete πŸ˜„ .
              Thank you.
              DESIGNER AND ARTIST DEREI.UK
                Thank you.
                They are completely different. TT_Lib2 can't be backwards compatible with TT_Lib - it's the whole reason why I made v2.
                However - I think the only plugin I released that use TT_Lib is Selection Toys - the rest was in development stage and was ported to TT_Lib2.
                There will be an major update to Selection Toys - then it will use TT_Lib2. Until then you need both libraries.
                • majidM Offline
                  majid
                  πŸ‘ thank you TT πŸ˜„. I like the feature of selectiong and converting group copies to component and use it ferequentely, but the confliction of selection toys and TT uv toolkit is a bit time consuming.
                  each time I must delete one of TT_lib folders.... 😞 hahhahahahah
                  waiting for next update, and thanks axain mate πŸ‘
                    @majid said:
                    :thumb: thank you TT πŸ˜„. I like the feature of selectiong and converting group copies to component and use it ferequentely, but the confliction of selection toys and TT uv toolkit is a bit time consuming.
                    What conflict?
                    I have them all running on my computer with no problem. TT_Lib is only used by Selection Toys.
                    UV Toolkit uses TT_Lib2.
                    • cottyC Offline
                      cotty
                      lunchtime? πŸ˜†
                      my SketchUp gallery
                        @cotty said:
                        lunchtime? πŸ˜†
                        Rendering πŸ˜’
                        Catching up for not being online while I was at Basecamp.
                        • 2 / 2
