    [Obsolete] TT_Lib (1.2.0) — 31 August 2010
    30 Posts 10 Posters 42.3k Views 10 Watching
      Yes it's the disavantages of the monopoly system if you don't want use it! 😄
      That is the first time that I am blocked 😉
      I will try your 000 number but for respect of your previous friends I will give a more hight number! 😄
      Sea spirit 😉
      http://www.comhonfleur.com/images/vieux_greements-_1.jpg
        If you sort the files in the Plugins folder by name you can see the load order. Name the file to whatever you want to control where it appears on the menu, just make sure it loads before the rest of the tt_*.rb files.
          Thx for the precision! 😎
            Starting a file name with # loads before any numbers/letter start...
              arjunmax09
              how can i use this plugin to manage my plugins?? 😒 I have no idea how to use this plugin...plz help
              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                You don't - it a shared library that some of my plugins use.
                  arqalexanderog
                  I get this error apology
                  Error loading file config.rb
                  No such file to load - TT_Lib / loading file json.rbError config_ini.rb
                  No such file to load - TT_Lib / loading file core.rbError inputbox.rb
                  No such file to load - TT_Lib / loading file gui.rbError tt_selection_toys.rb
                  No such file to load - TT_Lib / loading file core.rbError ui_manager.rb
                  No such file to load - TT_Lib / loading file core.rbError window.rb
                  I was not missing,
                  I cooperation could you please remove me from this little problem
                    How did you install it?
                    You should have a TT_Lib file in your Plugins folder, and all those files you mention in that error you got should be inside that.
                      arjunmax09
                      I was advised by KXI that this plugin was formerly known as plugin manager and could be used to manage junk plugins. How can I do this?
                        You can't.
                        It was previously intended to help manage plugins - but it was only for developers. It is only a library of reusable code.
                        • dereiD Offline
                          derei
                          Could you update TT_Lib2, or make another library for your plugins, as now I have TT_Lib and TT_Lib2. I just made some cleaning in my Plugins and I deleted TT_Lib, because I assumed that is obsolete 😄 .
                          Thank you.
                          DESIGNER AND ARTIST DEREI.UK
                            Thank you.
                            They are completely different. TT_Lib2 can't be backwards compatible with TT_Lib - it's the whole reason why I made v2.
                            However - I think the only plugin I released that use TT_Lib is Selection Toys - the rest was in development stage and was ported to TT_Lib2.
                            There will be an major update to Selection Toys - then it will use TT_Lib2. Until then you need both libraries.
                            • majidM Offline
                              majid
                              👍 thank you TT 😄. I like the feature of selectiong and converting group copies to component and use it ferequentely, but the confliction of selection toys and TT uv toolkit is a bit time consuming.
                              each time I must delete one of TT_lib folders.... 😞 hahhahahahah
                              waiting for next update, and thanks axain mate 👍
                                @majid said:
                                :thumb: thank you TT 😄. I like the feature of selectiong and converting group copies to component and use it ferequentely, but the confliction of selection toys and TT uv toolkit is a bit time consuming.
                                What conflict?
                                I have them all running on my computer with no problem. TT_Lib is only used by Selection Toys.
                                UV Toolkit uses TT_Lib2.
                                • cottyC Offline
                                  cotty
                                  lunchtime? 😆
                                  my SketchUp gallery
                                    @cotty said:
                                    lunchtime? 😆
                                    Rendering 😒
                                    Catching up for not being online while I was at Basecamp.
                                    • 2 / 2
