    Table Lamp [WIP]
    12 Posts 7 Posters 928 Views 7 Watching
      Don't post my models very often, i'm a little shy! 😳
      Here's a lamp i did to help me practice with Twilight.
      You can download it from here if you want?
      http://sketchup.google.com/3dwarehouse/details?mid=45fe5b6f45591fd47db10ce6a53eeed0
      And here's an attempt at rendering it, not happy with the glass yet, but feel free to tear me to shreds πŸ‘Š
      • Mike LuceyM
        Mike Lucey
        No need to be shy Rich, models are always welcome πŸ‘
        • E
          Ecuadorian
          Try the Realistic Glass > Plexiglass template and render with Easy 09.
          5-minute test with Preset 09
          -Miguel Lescano
          • D
            d12dozr
            Hi Rich,
            Its nice! I'd make the base shinier to get some nice reflections showing...maybe the Metal > Silver template. Posting WIP's to get feedback is one of the best ways to learn, so don't be shy πŸ˜„
            http://goo.gl/f7ooYh
            • tridemT
              tridem
              Hi Rich, I worked around a lamp a lot, looking for a good setting between the lamp itself emission and outfield light, it's very difficult and finally for the best result i took the picture with the lamp turned off! πŸ˜†
              • GaieusG
                Just playing around with a different lampshade and a copper body πŸ˜„
                only 10 passes with progressive prelim...
                  Thanks for the feedback it is very much appreciated and welcomed. πŸ‘
                  Mike - No need to be shy Rich, models are always welcome πŸ‘
                  Feels good to something back to this great community.
                  Ecuadorian- Try the Realistic Glass > Plexiglass template and render with Easy 09.
                  Top tip will definitely try it later and can i ask which material you used for the stand? Ideally I'd like a 'Tarnished Brass' or 'Antique Brass' but yours was fairly close to what i modelled from. I especially like the glass. πŸ‘
                  d12dozr - Its nice! I'd make the base shinier to get some nice reflections showing...maybe the Metal > Silver template. Posting WIP's to get feedback is one of the best ways to learn, so don't be shy πŸ˜„
                  Thanks d12dozr, I agree with you on that one πŸ‘
                  tridem - I worked around a lamp a lot, looking for a good setting between the lamp itself emission and outfield light, it's very difficult and finally for the best result i took the picture with the lamp turned off! πŸ˜† I think yours is a good starting work πŸ‘
                  Thanks, i agree with the difficulty, it's breaking my b#lls! 😲
                  Gaieus - Just playing around with a different lampshade and a copper body πŸ˜„
                  The bump you used on the glass, how did you achieve this? That bump and Ecuadorian's Plexiglass tip together is the exact finish i want.
                  Again thanks for taking the time to 'play around' with the model and give me some great advice
                  regards,
                  Rich
                  • GaieusG
                    It's a Kerkythea library called "patterned glass" materials (you should be able to find it in that jungle somewhere - I think Flatch has a sticky somewhere).
                    Anyway, since that's from alibrary, you cannot modify it (its colours) in TL but if you send the whole thing to KT, do what you want/can (and you can even save it as a new/modified mat.pack)
                    • FrederikF
                      Frederik
                      @gaieus said:
                      It's a Kerkythea library called "patterned glass" materials...
                      You can find and download it >>here<<...
                      @gaieus said:
                      ...you cannot modify it (its colours) in TL but if you send the whole thing to KT, do what you want/can (and you can even save it as a new/modified mat.pack)
                      Exactly... πŸ‘
                      You can see KT as the render studio application for Twilight Render, with an advanced material editor etc... πŸ˜‰
                      Cheers
                      Kim Frederik
                      • GaieusG
                        See, Kim, I am like an elephant. Leraning slowly but then I will remember forever.
                        πŸ˜’
                          Phew! For a minute i thought you were gonna say ....
                          I am like an elephant. Big ears, big nose and breath stinks of peanuts
                          • FrederikF
                            Frederik
                            Cheers
                            Kim Frederik
