    Editing string variables
    9 Posts 3 Posters 586 Views 3 Watching
    • honoluludesktopH
      honoluludesktop
      If I have a variable "mat" that is a string "FileName.Dxf", how do I edit the variable to remove ".Dxf"
      unless mat.nil?
         if e.is_a? Sketchup;;ComponentInstance or e.is_a? Sketchup;;Group then
            #String editing to remove ".Dxf" here
            e.material = mat
      Does my question make sense?
      • thomthomT
        For files there's a separate method for that: File.basename
        unless mat.nil?
              mat = File.basename(mat, ".Dxf")
              e.material = mat
        • thomthomT
          Alternatively, if the file type isn't always known:
          unless mat.nil?
                mat = mat.split('.').first
                e.material = mat
          • honoluludesktopH
            honoluludesktop
            Thanks, I am coding a plugin that allows me to texture imported components (dxf files) by applying a texture of a similar name to the imported component's name. In other words a imported component named "roof.dxf", will be textured by a material named "roof".
            • thomthomT
              Does it work to set entity.material = "stringName" ?
              • honoluludesktopH
                honoluludesktop
                Thomas, This is my first real attempt to understand ruby, so far its not working. Thanks for the help, I'll get it eventually.
                • honoluludesktopH
                  honoluludesktop
                  WooPee!! Got it. Ruby is case sensitive, and I was attempting the string conversion in the wrong place.
                  # Loop through entities & apply material based on layer name
                   Sketchup.active_model.entities.each do |e|
                       begin#if here found
                          #10/30/09 ignore file extention name start
                          stuff=e.definition.name
                          stuff=stuff.split('.').first
                          mat = su_materials[stuff]
                          #mat = su_materials[e.definition.name]#original
                          #end
                       rescue#else if here not found
                           mat = su_materials[e.name]
                       end#end if
                  Can't get over not having to declare variables. Dangerous for guys like me.
                  • M
                    MartinRinehart
                    The general way to do string fiddling in Ruby is via RegEx and it's not that hard:
                    x = 'asdf.wer'
                    # match string to regex; string =~ regex
                    # regex; '/'...'/'
                    # match into $1 and $2; string =~ /(...)(...)/
                    x =~ /(.*)\.(.*)/ # match (any number of any char)a period(more chars)
                    puts $1 # 'asdf'
                    puts $2 # 'wer'
                    Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                    • thomthomT
                      Plus, regex can handle the Unicode data from Sketchup, which SU's Ruby doesn't.
