    [REQ] import in place
    7 Posts 6 Posters 1.0k Views 6 Watching
    • rami_lpmR
      rami_lpm
      Hello everyone. I've been reading for some time and I wanted to thank you all for your wonderful tools.
      Now, on to the begging:
      I was in dire need of a plugin to import an skp file onto another without having to click to position (because that can cause mistakes). Something like a 'import in place' tool.
      I tried using sketchup.import, but i cant get rid of the positioning click.
      I was able to load the model i want to insert using Sketchup.find_support_file and definitions.load, but it forces me to have the model I want to load in the components directory(wich i can't modify, I.T. policy), plus once the model it's loaded i can't seem to find a way to insert an instance of it.
      I'm quite new(oob) to this ruby thing, so i wanted to ask you all for some help.
      • thomthomT
        Right Click a component -> Reload
        • K
          kwistenbiebel
          Or 'Copy' and 'Paste in Place'(Edit menu)
          • C
            CADAddict
            same as above.
            I always use Copy and Plaste In place, set it up as a shortcut and its perfect
            http://www.cad-addict.com/
            • X
              xrok1
              you can have two copies of sketchup opened at once, so select/copy in one (source) then paste in place to the other (target). 😉
              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
              • rami_lpmR
                rami_lpm
                well, it looks like this needed less code and more strategy.
                at the office we use a lot 'paste in place', so i'll stick to that, then turn my geometry(levels of a building) into components, save the components to separate files, and modify that files if i need to. I can reload the components and they will stay in the same location. problem solved.
                thanks everyone for the quick replies, you are awesome.
                • Chris FullmerC
                  TIG also has an x-ref stlye plugin. I have not used it, but I understand its pretty good.
                  Chris
                  All my Plugins I've written
