    Is there a script/plugin for making lines from units
    3 Posts 3 Posters 544 Views 3 Watching
    • A
      ashiboy
      example:
      I wanna make a line for 5 units and a unit is 80cm it draws a line of
      400cm.
      Like when u put number 5 in a textbox and hit enter it would create a
      line of 5X80cm in 1 line
      this is probebly not good explaned
      • GaieusG
        Well, I'd draw a line 80 cms and move-copy it along 4 more times.
        Or even better; draw a 400 cm long line and right click > Divide > type 5 and hit enter.
        • Jean LemireJ
          Jean Lemire
          Hi folks.
          Another possibility is to use an actual unit as your "unit".
          For example, draw a line that is 5 cm for a 5 "units" line.
          Do the whole model and, when done, scale up accordingly. In your example, you would scale up by a factor of 80.
          Just ideas.
