    Pencil overlay tutorial
    22 Posts 9 Posters 9.8k Views 9 Watching
      sepo
      You need image exported from Sketchup or a render , something like this...
      http://img10.imageshack.us/img10/6513/sponza.jpg
      By sepo100 at 2009-10-20
      Next thing you need is your pencil overlay. I have created image with pencil lines of 45 degrees.
      http://img199.imageshack.us/img199/3666/pencili.jpg
      By sepo100 at 2009-10-21
      Yo need to bring it in phtoshop or similar image editor as layer. You can change the colour of it, enlarge it, flip the angle or skew it, sharpen it or blur it. You also could selectively erase parts using something like 50% eraser strenght....etc. Experiment with % and mode of blending. You certainly need to manipulate it further to get the right output.
      So here is the one I did earlier. Happy blending.
      http://img35.imageshack.us/img35/8119/sponza1.jpg
      • Al HartA Offline
        Al Hart
        Nice work - thanks.
        You need to use Photoshop for an externally rendered image (although some external renderers support watermarks directly - applying the watermark as they render), but you should also be able to apply the pencil overlay directly to a SketchUp rendering using watermarks. Here is a SketchUp model with and without the pencil watermark using SketchUp styles
        SketchUp model with watermark
        http://wiki.renderplus.com/images/9/97/Star_Wars_Snow-Speeder-watermark.jpg
        SketchUp model with no watermark
        http://wiki.renderplus.com/images/2/22/Star_Wars_Snow-Speeder-no-watermark.jpg
        Al Hart
        http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
        IRender nXt from Render Plus
          sepo
          Yes I agree. The only problem is you can't really control blending and modes of blending as you can in Photoshop.
          • daleD Offline
            dale
            Had a project recently where I was asked to catch the "flavor" or a community market proposed for a small marina / housing development. I used several filters, and lots of layer adjustments, but I was really aiming for the look you have posted.
            Thanks for the post, I think it's worthwhile having a lot of diversity in your repertoire.
            SketchUp ----- Photoshop
              sepo
              I have noticed that "pencil" or "watercolour" look being more abstract are much more desirable early in design as clients or local authorities feel things are not fixed. Once design is agreed than PR images could fly much easier without having to justify again and again design.
              You can download that pencil image and try it. It works. 😉
              • Al HartA Offline
                Al Hart
                Here is another example where I applied the pencil image as a background (using Styles) and for soft shadows. (Using NprTools)
                Al Hart
                  sepo
                  The last one looks better.
                    sepo
                    I have made more detailed tutorial here
                    http://www.sketchupartists.org/?page_id=4254
                    • EarthMoverE Offline
                      EarthMover
                      Thanks Sepo...very helpful tip. Not digging the watermark technique too much....looks much better with the softness of a physical render overlay.
                      Content Creator at Skapeup
                        sepo
                        Thanks Adam. I do not like them as well. 😉 I think you need to have proper render and play with overlay in Photoshop or similar.
                          Daniel Bouchard
                          Thanks Sepo,
                          I have tried this technique on our ice castle image and the result is very interesting.
                          SU + Twilight + Sepo Pencil technique 👍
                            sepo
                            Daniel that does look quite interesting. You could mix the pencil layer with gradient or filter to get different tonal quality. I would also experiment with % of transparency and blends to get varied output. 👍
                            • E Offline
                              Ecuadorian
                              Thanks, Sid.
                              I see that more and more actually useful tutorials are being posted in SketchUp Artists. Ricardo Cossoli, Majid and Teofas wrote some good ones recently and didn't even bother to post an abridged version in the SCF.
                              Is the tutorials section of the SCF doomed to be a wasteland with only a few bright sposts (like Sepo's tut here) every once in a while? 😕
                              As David_H would say: Pause and discuss.
                              Anyway, I'm sure you'll reach a wider audience in SketchUp Artists, Sid, as no registering is needed to see the whole thing. 👍
                              -Miguel Lescano
                                sepo
                                Thanks Ecuadorian. The reason IMO people post on SketchUp Artist site is because it is primarily dedicated to tutorials and to promoting SU artists. Also while preparing your tutorial you get help from James and Mateo.
                                SCF is primarily forum and as such not really geared for tutorials. The downside in terms of tutorials on SCF is that you have other people hijacking your post with their own products. It is quite annoying actually. Look at me. I hijacked my own post. 🤣
                                • holmes1977H Offline
                                  holmes1977
                                  Cheers SEPO
                                  Great style, look forward to trying it out.
                                  Exaggeration makes a dull story better.
                                    EarthMover
                                    Thanks again Richard. I tried a combination of Majid's quick MLT NPR technique with your pencil overlay trick and a sketchy edges output overlay. Got an interesting result. It's really fun to play with this stuff!
                                    Quick 5 minute MLT output from Twilight
                                    Same image after NPR techniques
                                      sepo
                                      Thanks Holmes. I hope you enjoy it. 😄
                                      Richard? Who is Richard?
                                      I like that render with pencil overlay Adam.
                                        EarthMover
                                        Thanks James. Actually I just sold this job and the homeowner loved this NPR image better than the photoreal renders I did.
                                        Edit - Sorry bro...meant Sepo, not Richard. 😳
                                          sepo
                                          No problem Adam. I was only teasing you 😉
                                          BTW this proves my point that NPR renders are much more appreciated by Clients and Planning officers alike. The abstract notion in them enpowers clients/planners to have ownership and interpet the design in their own way. Once everything is put in place and agreed than PR images are great for advertising and brochures.
                                            mr cool
                                            Thank you!
                                            • 1 / 2
