    Video Quality?
    8 Posts 4 Posters 650 Views 4 Watching
    • W
      Windknot
      How can I make the video quality better when exporting from Sketchup?
      It just doesn't look that good.
      • honoluludesktopH
        honoluludesktop
        Did you select File > export > animation > options, and set options to 30fps, anti alasis, etc.?
        • GaieusG
          OR, I would even suggest to export as a series of images and compile the whole animation in a dedicated software. Hre is a tutorial (linked in a pdf format) by Paul Russam:
          http://forums.sketchucation.com/viewtopic.php?f=18&t=654&p=3728#p3728
          • W
            Windknot
            Yep.
            http://img291.imageshack.us/img291/1379/screenhunter01oct202129.jpg
            • W
              Windknot
              Thanks,
              I will check it out!
              • W
                Windknot
                Does anyone have any videos that they have done this way, so I can see what I am dealing with before spending $90 on the Adobe Premiere Elements?
                • GaieusG
                  You don't necessarily need that. I bet you already have Windows Movie Maker installed on your system (it may come with the OS) or use Virtual Dub or any of the very good quality freebies.
                  • John SayersJ
                    John Sayers
                    windknot - I've found that you must do 3 things.
                    1. the bigger the size the better - i.e 1230 x 901 at 16:9 res is better than 720 x 340 .
                    2. under codecs use full frame uncompressed
                    3. highest frame rate 30fps.
                    It will take hours to render and produce a 300meg plus file but it will look the best you can get out of sketchup and it will also compress down to a useable - web postable - size and retain the clarity.
