    SketchUP Model Giveaway - Azuma House by Ando
    13 Posts 8 Posters 3.3k Views 8 Watching
      bakbek
      I giving away my Azuma House model over at my blog to all those who subscribe to my newsletter.
      Head over and get it... if you like it.
      Just a moment...
      (www.ronenbekerman.com)
      • jim smithJ Offline
        jim smith
        Thanks for the link to your site - very well done, interesting and helpfull. (I have joined your mailing list)
        "Out of clutter find simplicity,
        from discord find harmony,
        In the middle of difficulty lies opportunity"
        Albert Einstein
        • E Offline
          Ecuadorian
          I saw this house in a book some years ago.
          This is begging to be rendered, thanks! 👍
          -Miguel Lescano
          • E Offline
            Ecuadorian
            Quick monochromatic attempt with Twilight, Easy 09:
            -Miguel Lescano
              bakbek
              [attachment=0:3153xffy]<!-- ia0 -->SketchUp output.jpg<!-- ia0 -->[/attachment:3153xffy]
              [attachment=1:3153xffy]<!-- ia1 -->Monochrome.jpg<!-- ia1 -->[/attachment:3153xffy]
              Cool! I guess the bump for the concrete needs more work to make the gaps deeper... never used Twilight before, seems very similar to Maxwell or Fryrender output.
              Does Twilight pick up the SketchUP sun position if want to do a day render?
                d12dozr
                Yes, and its very easy to get good results. Thanks for the model 😄
                http://goo.gl/f7ooYh
                • boofredlayB Offline
                  boofredlay
                  I remember Pete doing a great job with this house a while back using Podium.
                  http://forums.sketchucation.com/viewtopic.php?p=15931#p15931
                  • StinkieS Offline
                    Stinkie
                    OT: that Motiva Whatever Thingy looks sweet. Thanks for the tip, E.
                    • K Offline
                      kwistenbiebel
                      @Ecuadorian,
                      Wow man, those last renders simply rock. Got to get my hand on the Motiva thing as well as it certainly enhances the output considerably.
                      Warming up the textures was a very good idea. Nice work!
                      @Ronen (Bakbek),
                      Good to see you posting again.
                      I remember you being a very active Pushpullbar member some years ago. I thought you completely converted to 3D Studio later on so it's good to see you are still using SU.
                      • E Offline
                        Ecuadorian
                        Thanks, Kwisten. I saw Pete's great images back in January when I started using SketchUp, and I've wanted to play with this house since then. And I finally have a model! 😄
                        I've just returned from a meeting, and I left another image cooking while I was away. I'll just post the Motiva RealCamera-processed version, again simulating an Agfacolor HDC 400 plus camera.
                        -Miguel Lescano
                        • E Offline
                          Ecuadorian
                          And here it is. I warmed up the SketchUp textures, and added a couple of things from the 3D warehouse. Bamboo plant by Biebel 👍
                          This is the raw Twilight output:
                          And this is after opening the .hdr and tonemapping it with a camera effect in Motiva RealCamera:
                          -Miguel Lescano
                          • charly2008C Offline
                            charly2008
                            Hi Ronen,
                            i subscribed to your newsletter but i didn't get any E-Mail.
                            Karlheinz
                            • E Offline
                              Ecuadorian
                              As d12 said, Twilight can use SketchUp's sun. It's just that I did the first test with the sun turned off and a completely white sky for a moody, monochrome look.
                              Twilight has several render presets available. Some of them work similar to Indigo/Maxwell/Fry and are called "unbiased"; others work similar to V-ray/Mental Ray and are called "biased".
                              For the first test I used an unbiased preset, Easy 09. For the following one I used a biased one. I also turned off the light for a change, and enabled the physical sky + sun with some tweaks to their default values. Lastly, I did some post-production in the freeware app Motiva RealCamera, trying to simulate an Agfacolor camera. 💚
                              UPDATE: I'm cooking another one with Easy 09, wait for it...
                              -Miguel Lescano
