    Birdview map dimensions for all components
    2 Posts 2 Posters 534 Views 2 Watching
    • N Offline
      noblerabbit
      Greetings.
      I am new to the Sketchup. Generally I find it pretty easy to use. However i stumble upon a practical problem. Hopefully some of you will be able to help me.
      I built myself a closet from the components. Now I would like to make this closet a reality.
      1. So I would like to print a birdview map of all the components with dimensions so I can go to the store and the guys there cut this components from wood. Can sketchup do that?
      2. What would be also great... In store one can get wood usually in a rectangle dimensions (i bought 250cm long, 60cm wide and 1.8cm thick wood). So I bought four of these rectangle shaped wood plates. Can sketchup calculate the optimal alignment for how to cut components out of this plates so I dont waste so much wood?
      Thank you.
      Have a good day,
      I
      • Jean LemireJ Offline
        Jean Lemire
        Hi Noblerabbit, hi folks.
        For your question number 1 : Yes, see attached SU file for ideas (Scenes 1 to 3).
        For your question number 2 : No, unless there is a pluggin that can do that.
        However, you can use SU to help in the tedious task of optimizing the cuts. Don't forget to add some extra for the blade width (around 1/8 inch or 3 mm depending on the type of blade). See attached SU file for ideas (Scenes 4 to 8).
        Furniture parts list.skp
