    How to add components to another component? [ruby]
    6 Posts 5 Posters 698 Views 5 Watching
    • N Offline
      NewOne
      I want to select several component instances in my model, based on name, and group them in a bigger component.
      Something like this:
      Component#1 |
      Component#2 |--> Parent_Component
      Component#3 |
      Test#1 |
      Test#2 |
      Test#3 |--> Parent_Test
      Test#4 |
      Test#5 |
      But I really don't understand how. I thought I have to use entities.add_instance method, but I can't make it work. And there is a Transformation attribute which I don't understand. All I can do is to add a New empty component definition in model.
      Any help, please? Thanks.
      • chrisglasierC Offline
        chrisglasier
        Add component 1, 2 & 3 to selection; make selection component ... perhaps?
        With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
          cjthompson
          Can you explain how you select the components?
          The easiest way would to be what chrisglasier suggested. However, if you want to do it in a ruby script, one way would be:
          add a group, add the instances inside the group (group.entities.add_instance(instance.definition,instance.transformation)), delete the previous instances, and use group.to_component
          if you add a group, you don't have to worry about transformations.
            Jim
            The easiest thing to do..
            model = Sketchup.active_model
            selection = model.selection
            # use any array of entities
            g = model.entities.add_group(selection.to_a)
            g.to_component
            Note the API warns against using add_group in this way, but I don't think it will be a problem when adding Instances.
              chrisglasier
              > g.to_component
              You put the code right into my words!
                If you want to 'select' something ...
                ### Let's assume you have an array [list] of the items to add to the component, called 'list'...
                ### If you have selection made that has 'raw' faces in it then add those faces' edges too to the list, if those edges then have other faces those faces and edges too - '.all_connected. ???
                ### This is what causes bugsplats - when parts of 'connected things' are put into different entities sets...
                model=Sketchup.active_model
                selection=model.selection
                selection.clear
                selection.add(list)
                ### OR list.each{|e|selection.add(e)}
                ### then the code...
                g=model.active_entities.add_group(selection.to_a)
                inst=g.to_component
                inst.name="MyInstancesName"
                defn=inst.definition
                defn.name="MyComponentsName"
                ### check it hasn't incremented; using dname=defn.name; compare dname to "MyComponentsName", e.g. it might now be "MyComponentsName#1"
                ### etc...
