    Modelling by equation
    6 Posts 3 Posters 624 Views 3 Watching
    • M
      MIke Ravenwolf
      Hello everyone!
      Ok, here's the deal, I have an equation for a curve that i want to model within sketchup and I am wondering if this is possible, and if so, how would i go about doing it.
      The background behind this, I am designing a solar concentrator that uses two mirrors and I was hoping to be able to model it and do a ray trace on them just to see how they worked.
      any other suggestions would be helpful.
      Thanks !
      Mike
      Carpe Diem, Foveo Noctim
        I believe that you can import a matrix of points with a plug : Cloud V6 by Didier Bur
        So use Excel for exemple or Calc (free) from Open Open Office then import data πŸ˜‰
        • M
          MIke Ravenwolf
          yeah i have that plug, lol used it a few times.
          have not been successful at getting it to create faces very well. usually it gives up after only a few. and this is for a simple shape...lol. any suggestions on that?
          I was hoping to avoid going by that route as it would take quite a doing to get a decent shape, but if that is the route, then that is the route...lol
          thanks
            Wait some script answers' Gurus πŸ˜‰
            Another thing: make the render in Twilight ans see the path of light πŸ˜‰
            by Chris
            http://twilightrender.com/phpBB3/download/file.php?id=1275
            • M
              MIke Ravenwolf
              lol wow, that is awesome,
              yeah i was goign to try something like that with Kerky, though I might just have to give twilight a shot.
              I've not had too much lick with rendering in the past. so I am sure i'll be back with plenty of questions(and on the twilight forum)
              I'll have to toy around with Cloud to see if i can get it to do the surfaces I want.
              Tried to model a sinusoidal cam a few weeks ago, ended up having to join all the points by hand. lol was quite tedious to say the least.
              thanks again Pilou
              • Jean LemireJ
                Jean Lemire
                Hi Mike, hi folks.
                Make sure that the values that you will import are not too small. SU has problem creating faces with edges smaller than about 1 mm.
                It is best to import using meters as units and/or scale the points after import, if you want to make surfaces with them.
                Just ideas.
