WebDialog help - hide scrollbars
Thanks Thomas. BTW I think it therapeutic to use a STRICT doctype then abuse it by doing something non-standard - appeals to cynical Brits like me!
It's make the standard conformant me twitch. x_X
Ah!
There is a standard conformant way!html { overflow; hidden; }When removing
scoll="no"and adding that to the CSS the scrollbars disappeared in STRICT mode.Armed with that, you could sub-class the Webdialog class and tap into it's
.newmethod and pass on the scroll argument to the webdialog when it's ready. Unless you're fine with just having it defined in the CSS and ignore the Ruby argument.
I was going to make a wrapper for myself, that took care of the matter where the size is only being read the first time it's created. At the moment, if you try to change the size arguments for a non-resizable webdialog they won't take effect unless you purge the saved settings. -
Good and noted! And used here.
I don't know why I didn't try that before. I know that when switching between STRICT and quicks the behaviour of HTML and BODY changes.
Glad we finally worked it out. -
@newone said:
One more thing: JS statement element.selected = true; did not worked on my native SU instalation. After I updated my Internet Explorer from 6 to 7, it did worked... how is this possible, because in SU I still have IE4 ?
You don't have IE4 in SU. You have whatever is installed on the system.
That's one of the reason I would prefer is SU used a standalone web-frame that isn't linked to the system. -
That's one of the reason I would prefer is SU used a standalone web-frame that isn't linked to the system.Please run this.
@my_dialog = UI;;WebDialog.new('Check Version', false,"",400, 100, 300, 300, true) html = '<html> <body> <script type="text/javascript"> var browser=navigator.appName; var b_version=navigator.appVersion; var version=parseFloat(b_version); document.write("Browser name; "+ browser); document.write("<br />"); document.write("Browser version; "+ version); </script> </body> </html>' @my_dialog.set_html(html) @my_dialog.show{} @my_dialog.bring_to_front
You can't rely on
navigator.appVersion. Since IE4 and up it has always reported 4 for legacy support reasons. You must parse thenavigator.userAgentstring.
http://javascript.gakaa.com/navigator-appversion.aspx -
If so, why does it renders buttons so old-way?
IE is quick to do weird stuff to form control. In general - form controls in any browser is unpredictable.
If it'd been rendering like IE4 it would be permanently stuck in Quicks mode. Standard mode in IE wasn't introduced until IE6.
Sometimes Standards Compliant mode on MSIE turns MS Common Controls back to the old 'unthemed' set (they look like old Win 3.x ugly controls.)
See my post in the other WebDialog thread for a META tag that goes in the HEAD section.
Sometimes it can turn the 'XP themed' ver 6 controls back on.
I don't know if they work in Strict mode, but the tag should work for Tranistional mode.http://forums.sketchucation.com/viewtopic.php?f=180&t=22698#p196706
Register LoginAdvertisement
