    Layers
    2 Posts 1 Posters 284 Views 1 Watching
    • GaieusG
      Hi Niels,
      Are you using "color by layer"?
      Do you separate your "objects" by grouping them?
      Do you put geometry inside groups/components on other layers than Layer 0?
      Could you upload a simple example file where you experience what you thinks is not the correct way it should behave?
      • GaieusG
        OK, here how it should go:
        Never put "raw" (or "primitive" - i.e. ungrouped) geometry anywhere but always keep it on Layer0.
        Make a group of what you want to put on any other layer (or make a component if there will be more instances of the same geometry in your model) and only put those onto other layers.
