    Locking a view
    layout
    5 Posts 4 Posters 1.2k Views 4 Watching
      agrazdi
      Is there a way to lock a view ?
      I dimensioned a top view, but i edited it by mistake to the front view and when i tried to get it back, it wasn´t easy to match all the dimensions back.
      thanks
      agrazdi
        You couléd put it on a locked layer (see the layers in the tray).
          agrazdi
          The 2 answers will work for me
          thanks
          • honoluludesktopH Offline
            honoluludesktop
            Agrazdi, Assuming I understand your question, and your problem with getting back is because you are orbiting, I can think of two ways to get exactly back to where you were. First is to create a scene that you can return to, and if you have not changed the view too many times, just use "previous" to back up.
            • E Offline
              ericschimel
              As I said in another thread, I have layers for everything, title block, notes, dimensions, model, etc.
              The first thing I do when I send something to LayOut is setup the model view I want, and then lock that layer.
              -Eric
              http://plugin.sketchthis.net
              Sketchup Kitchen Design Plugin
              Custom Models
