    WebDialog question
    6 Posts 3 Posters 276 Views 3 Watching
    • N Offline
      NewOne
      hello, I want to pass two parameters like this:
      query = 'skp;send_values@' + val1 + 'WHAT HERE?' + val2;
      but I don't know how to concatenate val 1 + val2. I tried with @, with &, but doesn't work.
      Any suggestion ?
      • fredo6F Offline
        fredo6
        Any suggestion ?
        Unless val1 and val2 are strings, you need to convert them to strings.
        Use val1.toString()
        Fredo
        • N Offline
          NewOne
          Use val1.toString()
          Fredo
          I need them as array elements in ruby, that is why I want to concatenate them as separate parameters.
          • fredo6F Offline
            fredo6
            In Javascript you can use the .join() function (very similar to the Ruby one) to convert a list to a string with separator.
            for instance val1.join(';').
            The only thing you have to keep in mind is that the transmission to Ruby is done with a String after the @. So up to you to encode in JavaScript and decode in Ruby.
            Fredo
            • N Offline
              NewOne
              Fredo
              Thanks! This is what I am going to do. I will separate the string in ruby, to get desired array.
                MartinRinehart
                You might want to think about using JSON. It's a bit more general, can be really light weight and if you know JavaScript you already know JSON. Example:
                JSON array: comma-separated list of items enclosed in square brackets.
                Sample: ['string one', 'string two']
                It's a wee bit of extra work, but if you ever want to share data elsewhere ...
                Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
