    Creating a component that 'cuts through'
    5 Posts 2 Posters 833 Views 2 Watching
    • J
      jrexi
      Hi All,
      I am having a very hard time turning an inground pool I just modeled into a component that will cut through a surface. Basically, I want to be able to place the pool on a deck in different locations and have it cut through the deck no matter where I place it so you can see the depth of the pool and the deck surrounding the pool. I have spent hours turning the pool model into a component, choosing glue to any surface and made sure 'cut through' was checked off, but the problem is my pool component never cuts through the surface I place in on.
      I attached my model so if someone can point me in the right direction to get this to work, I would be greatly appreciative!
      Thanks in advance for your help.
      John
      lazy l right_22x41.skp
      • N
        NewOne
        Here is your cut-opening pool πŸ˜„
        lazy l right_22x41-cut opening.skp
        • J
          jrexi
          Thanks Newone! Can you let me know how you did it so I don't need to bug you when I model some other pool designs πŸ˜•
          • N
            NewOne
            Just build your component onto a face πŸ˜„. When you will select the geometry and press G (make component shortcut) you will see "cut face" option checked.
            • J
              jrexi
              ah, so that's the trick. Thank You so much!
