    [PROB] After a few hours, many command in context menu gone!
    4 Posts 3 Posters 388 Views 3 Watching
    • O
      orei
      Hi my friends.. i've a problem with my SU PRO.. everytime that use sketchup for a while.. after an hour.. many of the context menu command (with the right click over an element..) are unclickable.. for example.. the make group command.. is in gray.. and i need to go in edit menu and choose the command here..
      I can't solve this.. i've su pro 7.1 (but do this also with 7.0 last release..), with many many ruby script plugin.. but all of them are in the last relase.. i check that every day..
      anyone had the same problem??
      thanks a lot
      • D
        dedmin
        I had this too in 7.1!
        • soloS
          solo
          This is caused by a faulty ruby, the problem is finding which one.
          Adam (Earthmover) recently had a thread going with the same problem, not sure if his was solved, I had this issue a year or so ago and decided to dump all my ruby's and install them as I needed them, I never did install them all as some were outdated or improved and I never got that issue arise again.
          This is not a 7.1 issue.
          http://www.solos-art.com
          • O
            orei
            sorry my friends.. i'm a really bad forum user.. after post it.. i've immediatly found those topics..
            http://forums.sketchucation.com/viewtopic.php?f=15&t=21016
            http://forums.sketchucation.com/viewtopic.php?f=11&t=21812
            sorry... 😞
