    SketchUp 7.1?
    151 Posts 68 Posters 38.4k Views 68 Watching
    • AnssiA Offline
      Anssi
      @agrazdi said:
      @Lastsoftware -- we need you back, urgent !!!
      Do you mean the free version should be discontinued? A free version was totally a Google innovation. Otherwise, yes, I liked @Last quite well.
      Anssi
      • Chris FullmerC Offline
        In the blog statement they made a few weeks ago here:
        http://sketchupdate.blogspot.com/2009/08/coming-soon-in-google-sketchup.html
        They said this, towards the end (3rd to last paragraph)
        For those of you who depend on the importers we plan to remove, we'll be providing an optional download that enables them again. But remember! This installer will only be available for a limited time, and it will not be supported at all in our next major release.
        So they will support .dwg and .dxf for SketchUp FREE through the end of 7. But it will not be supported in SketchUp Free 8. It will continue to be supported in SketchUp Pro.
        Chris
        All my Plugins I've written
          ark
          Hurry Google!
          Just gave the free version a spin with old heavy model, and it's just much faster to update!
          It's a shame with the missing dwg/dxf import as I use it every time I start a project in sketchup, but now that Google takes this fine software seriously, I just might by the pro version 😄
          • F Offline
            fossa
            Hurry Google!
            Careful about that "taking it seriously" comment. IMO they have a long way to go before they even approach serious, when it comes to SU. Although this sure seems like a step in the right direction.
            Thank you SU team, let's keep things moving this way.
              Ehm...
              It seems that Google itself spilled out the beans a bit earlier than they were planning (good job IMO BTW - and I can still use some of nthese abbreviations more 😉 )
              Has any of you looked seriously into our "hardware test" down in the Corner Bar?
              OK, here are my results with SU 7.0 (shadows on):
              And here are the results with SU 7.1 (again, with shadows on)
              4.1 per seconds against 63.1 frames per seconds should speak for itself.
              Performance improvement? I can consider it to be.
              • dcauldwellD Offline
                dcauldwell
                Amazing results - must update right away!
                Thanks Google.
                Sketchup 2017
                (vray 2.00)
                • StinkieS Offline
                  Stinkie
                  Just tried the new release on my gf's iMac - there's a definite performance improvement. 👍
                    RonanR
                    All my models just orbit and zoom so much better.
                    For me the increase of performance alone makes this release a success...
                    %(#BF00FF)[Please keep signatures minimal.
                    Oh, and ditch incandescent light bulbs.]
                      dedmin
                      Agree 200%!!!! Sooo much smooth!!
                      • E Offline
                        ericschimel
                        Don't forget dimensioning in LayOut! This is a HUGE feature for those of us that make construction drawings...
                        They really did a nice job with the dimension tool...
                        -Eric
                        http://plugin.sketchthis.net
                        Sketchup Kitchen Design Plugin
                        Custom Models
                          drewpoeppel
                          Here is the link to turn on dwg/dfx import for the free version of 7.1. Like they said "only for a limited time"
                          http://sketchup.google.com/support/bin/answer.py?answer=161784
                          • jwlyon1J Offline
                            jwlyon1
                            Even though I have a pro license... I downloaded these just in case!!!
                            But otherwise, seems like a wonderful improvement.
                            Macbook Pro/ iMac
                            OSX 10.7.2 Sketchup 8
                            rogue-z is here!
                              Bert
                              I also noted that loading Scenes from Layout is much much faster
                              Salutations (Best regards) Bert
                                And to answer Drew's question from earlier, yes you can sort of install 7.0 and 7.1 separately. Well, you really make of copy of 7.0 before installing 7.1. I tried to write up how to do it here:
                                http://forums.sketchucation.com/viewtopic.php?f=15&t=22158&start=0&st=0&sk=t&sd=a
                                Chris
                                • P Offline
                                  paulside
                                  Dimensioning in Layout!
                                  Its so much more useful now - thanks Google,
                                  If you could now just give Layout: an offset line tool, a hatch pattern fill option and a parallel line tool (Maybe SketchUp 8 ?) I can ditch all my other CAD software.
                                  It orbits so much more smoothly as well,
                                  Thanks SketchUp Team 👍
                                    matteo
                                    I've noticed that sketchup uses both cores of my processor when i change view (pan, zoom & rotate).
                                    I'm running it on windows xp 32 bit sp3.
                                    Does it explain all (or partially) that gain of speed, or was it the some before the 7.1 release?
                                    /matteo
                                    hire me: http://www.nonsolo3d.it/ !
                                      /matteo
                                      Hm... Lucky you then - I don't think SU would (natively) make use of multicore yet.
                                      But of course, I might be wrong. 😕
                                      • E Offline
                                        Ecuadorian
                                        It seems Windows XP has the ability to distribute loads to both cores even if the program you're running isn't multi-threaded. I've seen this several times, especially in my Kerkythea animation tests. When I set it to use only one thread, it still used both cores, but it was an imbalanced load:
                                        http://www.kerkythea.net/phpBB2/viewtopic.php?p=63700#63700
                                        But of course, it might be that they quietly mutithreaded SketchUp.
                                        -Miguel Lescano
                                        • soloS Offline
                                          solo
                                          I guess the Google guys looked here first at our concerns as the two longest gripe threads after version 7 was released was 1) performance and 2) the component back button, and as far as I can see they attended to those.
                                          I've stuck to SU6 pro until now, as now version 7 has grown up and a great reason to upgrade.
                                          http://www.solos-art.com
                                          • daleD Offline
                                            dale
                                            I always had some difficulties with SU7(PRO), nothing major, just glitches that never occurred in SU6, and even reverted back to 6 for some large models. So I thought there was nothing to lose and downloaded away.
                                            So far I like what I see. The performance on big gluttonous models is quite surprising. It will be interesting to see if the gremlins disappear.
                                            • 6
                                            • 7
                                            • 8
                                            • 2 / 8
