    Kerkyhea Materials in Twilight
    extensions
    3 Posts 3 Posters 944 Views 3 Watching
    • charly2008C
      charly2008
      Hi to all,
      perhaps others have already discovered that the Kerkythea materials can also be used in Twilight. The idea came to me when i read that Twilight could be a little similar to Kerkythea render machine.
      Karlheinz
      • soloS
        solo
        And it's been mentioned on the Twilight forum with links to the KT material downloads as well.
        http://www.solos-art.com
        • FrederikF
          Frederik
          It's no secret that Twilight uses the KT SDK (based on Kerkythea 2008 Echo), so you can say that it's KT build into SU with A LOT of things that should make it really easy to use... 😉
          In the tutorials you can easily learn how to use KT materials directly in Twilight Render... 😉
          Cheers
          Kim Frederik
