    A different way to use TwilightRender...
    20 Posts 13 Posters 3.5k Views 13 Watching
      tomsdesk
      ...whadaya think?
      2.5D Trees & Shrubs!
        troyhome
        i think it's great- how'd ya doit?
        IOviz.com
        SU Pro 2024 PC
        • E Offline
          Ecuadorian
          I'm asking myself the same thing. Looks very natural. Tomsdesk has been trying NPR techniques since I can remember, but this one turned out particularly well. Actually, this could mean no one needs Piranesi anymore.
          -Miguel Lescano
          • F Offline
            fymoro
            Wow !! This image is really nice and artistic, give us the secret, Thanks.... 🎉
            Fred.
            http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
              dylan
              That is a nice style Tom, look forward to hearing how you achieved this.
              http://dmdarchitecture.co.uk/
              • N Offline
                notareal
                +1
                  tomsdesk
                  Okay...sure, and thanks: as long as ya'll promise to share back whatever tweaks and discoveries you make to make it better. First here's another image more indicative of the use of TwilightRender (the water reflections...didn't use any lights here):
                  start with tomsdesk growies...specifically made for NPR images :`)
                  render scene in Twilight (this one is Low+ 1000wide...subtle light cast shadows take a little bigger and better and a lot longer)
                  blowup the render to whatever size works for you to get the desired results after simplification...see the next step (this one is 5000wide), then postprocess as you like (here just did a little "soft light" and sharpen on the center)
                  simplify the enlarged postpro image (I used to use the trace function in CorelDraw, but had to add brushstrokes with a layer or two from SnapArt and do a lot of tweaking...this one is FotoSketcher only...the next one: who knows? :`)
                  postpro the simplified image as you like (here I hit it with BeyondEdger4)
                  add a sketchy white edge/border/frame to the postpro simplified image (I use Professor Franklin...anybody know a source for free ones similar to this? please share, thanks)
                  do a sketchy line work only (hiddenline, no shadows) export from SU same size as your enlarged render
                  throw them all into the pot (I use PSP): line only on the bottom (this one set to normal), edged postpro simplified render next (this one set to multiply), enlarged postpro render next (this one set to soft light), finally a layer of grey dots made from a paper texture (set to burn)...adjust the transparencies as you like (beef up the line work with another layer of it set to multiply or burn if you want)
                  =walla
                  BTW...here's the render:
                  http://forums.sketchucation.com/viewtopic.php?f=81&t=22042
                  • majidM Offline
                    majid
                    It is amazing mate 😄 congrats. also I was working on a similar trick that is based on MLT settings for a while and will be out soon. I've tried to simplify the steps as possible.
                    here is a sample
                    • RichardR Offline
                      Richard
                      here is a sample
                      Mate that is simply stunning, one of the best NPR's I've seen seriously! - care to start a thread on your workflow! Maybe link here too so it's not lost in the haze.
                      BUILTBRAND.COM.AU
                      • majidM Offline
                        majid
                        thanx mate 😄 . after modeling it is less than a quarter of rendering and post pro jobs to reach such NPR render. probably I'll share it over the sketchup artists web page , and start the discussion here. I've learned alot from these sort of discussions.
                        • MALAISEM Offline
                          MALAISE
                          Very refreshing Style, Tom. Glad to learn how you do it . 😄
                          MALAISE
                            dylan
                            I agree, that is stunning Majid, a really exceptional looking image.
                            • artysmediaA Offline
                              artysmedia
                              I see here great render results. It is kind of magic! ☀
                              Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                              Blog: Artysmedia
                              • majidM Offline
                                majid
                                it is amazing that you are interested in this jobs, here is the same trick for an exterior scene:corners are dodged using PS
                                  mateo soletic
                                  Amazing work Majid and Tomdesk. Congrats 👍 👍
                                  Some of the best npr works I have seen for some time.
                                  No offense but this last exterior image is my favorite. 👍
                                  Mateo
                                  Concept Illustrations
                                  • RichardR Offline
                                    Richard
                                    Mateo
                                    BUILTBRAND.COM.AU
                                    • majidM Offline
                                      majid
                                      ok mates, here is link to tutorial on sketchupartists:
                                      http://www.sketchupartists.org/?page_id=3318
                                      and I'll start discussion on our site too.
                                      (edited: here is the link: http://forums.sketchucation.com/viewtopic.php?f=81&t=22093)
                                      • P Offline
                                        PKast
                                        Tom & Majid I was away for a week, and was stunned to see what I have missed.
                                        Tom, I loved what you were doing with Twilight, (as I watched that post with some interest) and I am extremely fond of what you are doing in these images. I thought the first image was spectacular, but the second is even more stunning. Thanks for sharing.
                                        Majid I also like very much your images, both are fantastic. I will be looking over your tutorial with great interest as soon as I can.
                                        Best
                                        Peter
                                          troyhome
                                          here is a sample
                                          wowowzers! i like this one lot!
                                          IOviz.com
                                          SU Pro 2024 PC
                                          • majidM Offline
                                            majid
                                            thanx mate, now it is published here:
                                            http://www.sketchupartists.org/?page_id=3318 and here is the discussion:
                                            http://forums.sketchucation.com/viewtopic.php?f=81&t=22093 cheers 😄
