    A different way to use TwilightRender...
    20 Posts 13 Posters 4.0k Views 13 Watching
    • N
      notareal
      That is a nice style Tom, look forward to hearing how you achieved this.
      +1
      • T
        tomsdesk
        Okay...sure, and thanks: as long as ya'll promise to share back whatever tweaks and discoveries you make to make it better. First here's another image more indicative of the use of TwilightRender (the water reflections...didn't use any lights here):
        start with tomsdesk growies...specifically made for NPR images :`)
        render scene in Twilight (this one is Low+ 1000wide...subtle light cast shadows take a little bigger and better and a lot longer)
        blowup the render to whatever size works for you to get the desired results after simplification...see the next step (this one is 5000wide), then postprocess as you like (here just did a little "soft light" and sharpen on the center)
        simplify the enlarged postpro image (I used to use the trace function in CorelDraw, but had to add brushstrokes with a layer or two from SnapArt and do a lot of tweaking...this one is FotoSketcher only...the next one: who knows? :`)
        postpro the simplified image as you like (here I hit it with BeyondEdger4)
        add a sketchy white edge/border/frame to the postpro simplified image (I use Professor Franklin...anybody know a source for free ones similar to this? please share, thanks)
        do a sketchy line work only (hiddenline, no shadows) export from SU same size as your enlarged render
        throw them all into the pot (I use PSP): line only on the bottom (this one set to normal), edged postpro simplified render next (this one set to multiply), enlarged postpro render next (this one set to soft light), finally a layer of grey dots made from a paper texture (set to burn)...adjust the transparencies as you like (beef up the line work with another layer of it set to multiply or burn if you want)
        =walla
        BTW...here's the render:
        http://forums.sketchucation.com/viewtopic.php?f=81&t=22042
        2.5D Trees & Shrubs!
        • majidM
          majid
          It is amazing mate πŸ˜„ congrats. also I was working on a similar trick that is based on MLT settings for a while and will be out soon. I've tried to simplify the steps as possible.
          here is a sample
          • RichardR
            Richard
            here is a sample
            Mate that is simply stunning, one of the best NPR's I've seen seriously! - care to start a thread on your workflow! Maybe link here too so it's not lost in the haze.
            BUILTBRAND.COM.AU
            • majidM
              majid
              thanx mate πŸ˜„ . after modeling it is less than a quarter of rendering and post pro jobs to reach such NPR render. probably I'll share it over the sketchup artists web page , and start the discussion here. I've learned alot from these sort of discussions.
              • MALAISEM
                MALAISE
                Very refreshing Style, Tom. Glad to learn how you do it . πŸ˜„
                MALAISE
                La Connaissance n'a de valeur que partagΓ©e
                  dylan
                  I agree, that is stunning Majid, a really exceptional looking image.
                  http://dmdarchitecture.co.uk/
                  • artysmediaA
                    artysmedia
                    I see here great render results. It is kind of magic! β˜€
                    Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
                    Blog: Artysmedia
                    • majidM
                      majid
                      it is amazing that you are interested in this jobs, here is the same trick for an exterior scene:corners are dodged using PS
                        mateo soletic
                        Amazing work Majid and Tomdesk. Congrats πŸ‘ πŸ‘
                        Some of the best npr works I have seen for some time.
                        No offense but this last exterior image is my favorite. πŸ‘
                        Mateo
                        Concept Illustrations
                        • RichardR
                          Richard
                          Mateo
                          πŸ‘
                          BUILTBRAND.COM.AU
                          • majidM
                            majid
                            ok mates, here is link to tutorial on sketchupartists:
                            http://www.sketchupartists.org/?page_id=3318
                            and I'll start discussion on our site too.
                            (edited: here is the link: http://forums.sketchucation.com/viewtopic.php?f=81&t=22093)
                            • P
                              PKast
                              Tom & Majid I was away for a week, and was stunned to see what I have missed.
                              Tom, I loved what you were doing with Twilight, (as I watched that post with some interest) and I am extremely fond of what you are doing in these images. I thought the first image was spectacular, but the second is even more stunning. Thanks for sharing.
                              Majid I also like very much your images, both are fantastic. I will be looking over your tutorial with great interest as soon as I can.
                              Best
                              Peter
                              • troyhomeT
                                troyhome
                                here is a sample
                                wowowzers! i like this one lot!
                                IOviz.com
                                SU Pro 2024 PC
                                • majidM
                                  majid
                                  thanx mate, now it is published here:
                                  http://www.sketchupartists.org/?page_id=3318 and here is the discussion:
                                  http://forums.sketchucation.com/viewtopic.php?f=81&t=22093 cheers πŸ˜„
