    Report just one attribute
    11 Posts 3 Posters 601 Views 3 Watching
      artofseeing
      hi all,
      i'm working on the following script:
      require 'sketchup.rb'
      def gewicht
        model = Sketchup.active_model
        selection=model.selection
        entity=selection.first
        entities=selection[1]
      attdict=entity.attribute_dictionary "dynamic_attributes"
       definitions = model.definitions
       component = definitions[0]
      #value = model.get_attribute "dynamic_attributes", "gewicht", 0
       keys=attdict.keys[-4]
      value=attdict.values[-4]
      #UI.messagebox [keys, "; ", value]
       UI.messagebox [component.name, " ;", "Einzel-Gewicht;", value, " ", "kg"]
      if( not file_loaded?("SINUS-gewichte.rb") )
        toolbar = UI;;Toolbar.new "SINUS"
        cmd = UI;;Command.new("SINUS") {
           gewicht
           cmd.small_icon = "weight.gif"
           cmd.large_icon = "weight.gif"
           cmd.tooltip = "Gewicht"
           cmd.status_bar_text = "Gewicht"
           cmd.menu_text = "Gewicht"
           toolbar = toolbar.add_item cmd
           toolbar.show
      i set the key index to -4 because "gewicht" is the one key i need.
      any better way to retrieve a key by its name?
      but the script doesnt quite work yet the way i want it to.
      i want to do the following:
      selct one or more components i draged and dropped from my library.
      (they already have a "gewicht" key with corresponding value attached to them under the dictionary "dynamic_attributes"!)
      "gewicht" means weight by the way.
      now:
      i want a messagebox to show me the following:
      the single weight of each selected component
      the sum of weights of all selected.
      that's practically it.
      any suggestions?
      thanks πŸ˜„
      cheers.
      as long as there is a voyage away, there's always a journey back...
      http://artofseeing.carbonmade.com
        model=Sketchup.active_model
        ss=model.selection
        gewicht=0
        ss.each{|e|
          if e.class==Sketchup;;ComponentInstance
            gewicht=gewicht + e.definition.get_attribute("dynamic_attributes","gewicht",0)
          end#if
          # If the component definition has no gewicht then its gewicht = 0
          # Wenn die Komponente Definition hat keine gewicht dann seine gewicht = 0
        UI.messagebox("Gesamtgewicht = " + gewicht.to_s + " kg")
        This should work?
        Diese Arbeit sollte?
          artofseeing
          wow thanks for the qucik and helpful reply.
          when i select nothing its okay.
          iget this error in the console when i have a component selected:
          Error: #<TypeError: String can't be coerced into Fixnum>
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SINUS-gewichte.rb:13:in +' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SINUS-gewichte.rb:13:in gewicht'
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SINUS-gewichte.rb:11:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SINUS-gewichte.rb:11:in gewicht'
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SINUS-gewichte.rb:30
          C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/SINUS-gewichte.rb:29:in `call'
          any suggestions?
          again, thanks πŸ˜„
            cjthompson
            I haven't actually tested this, but I'm guessing this should work
            to:
            gewicht=gewicht + e.definition.get_attribute("dynamic_attributes","gewicht",0).to_f
              If 'gewicht' is always a number it should add OK to the earlier version of itself...
              Maybe initially set gewicht=0.0 so it's a float rather than an integer ?
              Then use cjt's gewicht=gewicht + e.definition.get_attribute("dynamic_attributes","gewicht",0.0).to_f
              Try puts e.definition.get_attribute("dynamic_attributes","gewicht",0.0) inside the {} so that you see in the ruby console what it's doing...
                cjthompson
                do you want one messagebox with each weight and one with the sum, or do you want one with both the sum of the weights and each weight?
                  artofseeing
                  actually, i need one messagebox with all weiths shown(sum and single),
                  as a checkup if it got all the data right.
                  then im gonna take what the messagebox has shown and save it first as a simple text file,
                  in the end even paste the data into cells of a scalc file where i can
                  estimate the final loads at certain points.
                  i.e.:
                  i have 10 lamps and 2 beamers and 4 loudspeakers hanging on a line of truss,
                  so i get all the weights of each part, and the sum.
                  this truss is i.e. hanging at 2 points, so i estimate half the final load to each point.
                  so in the end, its a load calculation, which, up to now, i always had to do by hand.
                  πŸ˜„
                    artofseeing
                    got it!
                    the guess was right.
                    make all values and variables floats, and it works out.
                    i selected none> weight=0
                    i selected one> weight=6
                    i selected 2> weight=12
                    thanks guys:)
                    now to get also the single weights...
                    but i can do that.
                      artofseeing
                      one more strange happening yet:
                      ijust found out that
                      the sum of weights i get is a rounded value.
                      for example:
                      a lamp has the value "15,4" for the key "gewicht".
                      if i report on that i get "15.0"
                      cant seem to figure out just why... πŸ˜•
                        artofseeing
                        got it1
                        it was my error writing "15,4" instead of "15.4" into the value
                        πŸ˜„
                          @artofseeing said:
                          got it1
                          πŸ˜„
                          German decimal points 1,2 == 1.2 !!! πŸ˜‰
