    Mysterious warning when opening SU
    8 Posts 3 Posters 501 Views 3 Watching
    • troyhomeT Offline
      troyhome
      Clearly this is an error caused by a ruby script- i assume.. but i can't find anything in my plugins folder called date.rb
      Does this simply mean i'm MISSING date.rb?
      anyone?
      IOviz.com
      SU Pro 2024 PC
        Have you searched subfolders in your pluging?
        Sounds that it tried to reference a DateTime class that's missing.
        • troyhomeT Offline
          troyhome
          i did a subfolder search to no avail. what is a DateTime class? can i get a new one? do i sound totally clueless: 😳
          IOviz.com
          SU Pro 2024 PC
            Jim
            date.rb does not come with Sketchup, and some plugin adds it to the Sketchup/Tools folder - one of the RenderPlus plugins maybe?
            Did you install or uninstall a plugin recently?
            • troyhomeT Offline
              troyhome
              I did indeed install and uninstall several plugs recently and foolishly did not track them at all!! and since then i have done so much to my files that sorting by date modified gives me no clues. I don't have RenderPlus installed...
              IOviz.com
              SU Pro 2024 PC
              • troyhomeT Offline
                troyhome
                mmm... there IS a date.rb in the Tools folder- i only did a search of the Plugins subfolders... i'll try to remove it and see what happens!
                IOviz.com
                SU Pro 2024 PC
                • troyhomeT Offline
                  troyhome
                  removing date.rb makes SU hang on startup...
                  IOviz.com
                  SU Pro 2024 PC
                  • troyhomeT Offline
                    troyhome
                    okay- SU was hanging for some other reason; removing date.rb from the Tools folder has made the dialog box go away. who knows what else will be affected, but at least all is well right now. Thanks for the input.
                    IOviz.com
                    SU Pro 2024 PC
