    Viccarbe Wrapp
    2 Posts 2 Posters 752 Views 2 Watching
    • thomthomT
      Does anyone know of a clean low-ish-poly version of the Viccarbe Wrapp chair?
      I downloaded a zip from their site, containing IGES and STL - just they end up so heavy. Those files seem to consist of multiple surfaces that aren't joined together - so you can see visible seams after importing. (I tried to import with Rhino and save as .3ds.)
      The site also says the zip should contain DWG files - but I find none there. I somewhat doubt it would be better anyway.
      Tried FormFonts - no results for Viccarbe. 😞
      Anyone got some suggestions?
      • brodieB
        brodie
        http://sketchup.google.com/3dwarehouse/details?mid=6be3e544deece8441191025061735ea3&prevstart=0
        This one doesn't seem too bad. Probably could be a bit lower poly but it seems like a fairly clean model.
        -Brodie
