    Save/Restore SketchUp 7 Workspace for Windows
    31 Posts 17 Posters 14.2k Views 17 Watching
      ahnvtk
      sketch3d.de:
      [notwithstanding how long ago these posts were..] I was really hoping your program would solve this great annoyance in SketchUp 7 running on Windows 7; here's what happens:
      When I click "Save", the dialog just disappears and reappears. Then when I go to "Restore", it brings up a file dialog prompting for a .reg file.. but no reg file was ever saved (or I don't know where), nor was I prompted to save one. 😞
      As for the script that started this thread, though it's necessarily complicated (why hasn't google addressed this annoyance??), it's a lifesaver, so THANX Jim!
      • sketch3d.deS Offline
        sketch3d.de
        found & fixed
        also some GUI changes.
        have fun,
        Norbert
          supangkat
          is there any .bat for skethcup 8 please???? 😳
            Jim
            Open the .bat in notepad.exe, edit the number 7 in line 20 - make it an 8.
              jla303
              This Script is awesome, works great!
              It saves me a lot of time not to re arrange my workspace on a dual monitor.
              Thanks Jim
              • P Offline
                Pavel_G
                Hi.
                Is it possible to transfer tool-bar position settings between SU versions (from 7 to 8 in my case)? BackUping SU7 prefs and using this .reg file fore restoring SU8 (Windows executable by sketch3d.de) didn't work.
                Thanks in advance.
                  sketch3d.de
                  the tool did not do any version conversion, selecting the SU version has effect on backing up only.
                  N.
                  • E Offline
                    elatiara
                    wow great script thank you. I'm about to re-installing my SU from google to trimble, glad i found this thing
                      sketch3d.de
                      @luds said:
                      ...seem to work normally, but nothing is saved.
                      could be missing user rights (see lower left corner), try if running by "Right-Click > Run as Admin..." works.
                      • LudsL Offline
                        Luds
                        Thank you for your help. I have tried the Right-Click > Run as Admin... and still nothing is saved. No go, it does not work. Nothing is saved. I am running SketchUp 2015 (v15.3.331) on Win8 x64, and no modification was made at time of setup - normal setup ie: C:\Program Files\SketchUp\SketchUp 2015.
                        Here are an image showing the settings prior to clicking the "Backup" button.
                        • Scroll down to see it:
                          http://imagik.fr/view-rl/149139
                        http://www.heberger-image.fr/images/34554_Su_backup.jpg.html
                        Edit : this is all fixed with BackUp Prefs 1.16 f. Windows. Yeah !!! Thank you to the developer. β˜€
                        • LudsL Offline
                          Luds
                          @sketch3d.de said:
                          I've made a Windows executable for saving/restoring the SU prefs (no malware, no spyware, no adware, no installation).
                          tested w/ XP, should work w/ Vista/7 too; even though, use at own risk.
                          Norbert
                          Script from sketch3d.de (Norbert) looked really promissing and easy to use πŸ˜„ . Thank you. Unfortunately, no go on Windows 8.1 with Sketchup 2015 (x64) as the script opens and seem to work normally, but nothing is saved.
                          Tried to save in 'Documents folder" to start with, then created a folder on the desktop, still no go. So unfortunately not working for me... 😞 Thank you anyway 😐
                          • 2 / 2
