    Save/Restore SketchUp 7 Workspace for Windows
    31 Posts 17 Posters 15.2k Views 17 Watching
      agrazdi
      I tried in a Windows Vista and all i get is " Access denied " any idea the reason ? Firewall ?
      agrazdi
        remus
        are you using an admin account? can you right click->run as administrator?
        • I Offline
          inbal
          Thank you soooo much!
          I keep having my plugins and toolbars scrambelled and I spent so much time on arrenging them.
          Thank you for saving me time πŸ˜„
          • sketch3d.deS Offline
            sketch3d.de
            I've made a Windows executable for saving/restoring the SU prefs (no malware, no spyware, no adware, no installation).
            tested w/ XP, should work w/ Vista/7 too; even though, use at own risk.
            just holler if anything doesn't work or a something is missing.
            Norbert
              ahnvtk
              sketch3d.de:
              [notwithstanding how long ago these posts were..] I was really hoping your program would solve this great annoyance in SketchUp 7 running on Windows 7; here's what happens:
              When I click "Save", the dialog just disappears and reappears. Then when I go to "Restore", it brings up a file dialog prompting for a .reg file.. but no reg file was ever saved (or I don't know where), nor was I prompted to save one. 😞
              As for the script that started this thread, though it's necessarily complicated (why hasn't google addressed this annoyance??), it's a lifesaver, so THANX Jim!
                sketch3d.de
                found & fixed
                also some GUI changes.
                have fun,
                Norbert
                  supangkat
                  is there any .bat for skethcup 8 please???? 😳
                    Jim
                    Open the .bat in notepad.exe, edit the number 7 in line 20 - make it an 8.
                      jla303
                      This Script is awesome, works great!
                      It saves me a lot of time not to re arrange my workspace on a dual monitor.
                      Thanks Jim
                        Pavel_G
                        Hi.
                        Is it possible to transfer tool-bar position settings between SU versions (from 7 to 8 in my case)? BackUping SU7 prefs and using this .reg file fore restoring SU8 (Windows executable by sketch3d.de) didn't work.
                        Thanks in advance.
                          sketch3d.de
                          the tool did not do any version conversion, selecting the SU version has effect on backing up only.
                          N.
                          • E Offline
                            elatiara
                            wow great script thank you. I'm about to re-installing my SU from google to trimble, glad i found this thing
                              sketch3d.de
                              @luds said:
                              ...seem to work normally, but nothing is saved.
                              could be missing user rights (see lower left corner), try if running by "Right-Click > Run as Admin..." works.
                              • LudsL Offline
                                Luds
                                Thank you for your help. I have tried the Right-Click > Run as Admin... and still nothing is saved. No go, it does not work. Nothing is saved. I am running SketchUp 2015 (v15.3.331) on Win8 x64, and no modification was made at time of setup - normal setup ie: C:\Program Files\SketchUp\SketchUp 2015.
                                Here are an image showing the settings prior to clicking the "Backup" button.
                                • Scroll down to see it:
                                  http://imagik.fr/view-rl/149139
                                http://www.heberger-image.fr/images/34554_Su_backup.jpg.html
                                Edit : this is all fixed with BackUp Prefs 1.16 f. Windows. Yeah !!! Thank you to the developer. β˜€
                                • LudsL Offline
                                  Luds
                                  Norbert
                                  Script from sketch3d.de (Norbert) looked really promissing and easy to use πŸ˜„ . Thank you. Unfortunately, no go on Windows 8.1 with Sketchup 2015 (x64) as the script opens and seem to work normally, but nothing is saved.
                                  Tried to save in 'Documents folder" to start with, then created a folder on the desktop, still no go. So unfortunately not working for me... 😞 Thank you anyway 😐
                                  • 2 / 2
