    Roundedge around a curved path
    4 Posts 3 Posters 427 Views 3 Watching
      T1000
      Hello,
      I'm trying to round an edge around a curved path. I've tried two different methods to achieve this:
      1. Drawing a quarter circle + follow me (first picture below)
      2. Using push-pull to extrude the raise section, then using RoundEdge by Bezier.
      In both cases, the result ends in the second image below, where SU just can't handle rounding an edge along a curved path.
      http://img42.imageshack.us/img42/5463/54891955.th.jpg
      http://img190.imageshack.us/img190/9865/39137632.th.jpg
      Any help / suggestions to resolve this would be much appreciated.
      Thanks.
        remus
        If your model is pretty small SU can have trouble drawing the faces. If you scale your model up x10, round the edges, then scale down x0.1 that should fix the issue.
          I guess the problem is what Remus says so follow his tips. πŸ‘
            T1000
            Thanks for the solution. Problem now solved.
