    Hello
    3 Posts 2 Posters 324 Views 2 Watching
    • H
      Hoof
      Sketchup newbie here.
      Background = oldschool: used to use Symbolics (Lisp-based poly modeller from late 80s) now getting back into 3d for games.
      First newbie question: is there a plugin for replicate+transform in space: eg take a selected poly, move it + 1 on the x relative to current position, scale by 0.5, do this operation three times?
      thanks!
      • R
        remus
        I think TIGs Grow plugin will do it, although im not sure how you use it.
        • H
          Hoof
          Wow, speedy response: thanks Remus. I'll see if Grow does the trick
          FWIW Jim's Mover2 is nearly what I need, except it doesn't do multiple iterations, or scales as the name implies. Pretty good apart from the sticky 'copy' toggle which needs to be a radio button I think.
          http://sketchuptips.blogspot.com/2007/08/plugin-mover-2.html
