    [Plugin] Axis components (Updated 6/12/2010)
    27 Posts 15 Posters 31.3k Views 15 Watching
      sahi
      axiscomp5.zip
        dedmin
        Yee, i was about to ask for something like this when i saw your plugin!!! Thanks!! Is there a way to position component axes on the edges of the bounding box and the centers of their sides - there is a command in Rhino that makes a bounding box of an object or group of objects that i used for centers of the blocks!
        Б ольшое спасибо!
        • Chris FullmerC Offline
          Great plugin idea Sahi! I'll check it out when I get a chance. Thanks for contributing it here,
          Chris
          All my Plugins I've written
          • urgenU Offline
            urgen
            ....А-а-атлично! 👍 👍 👍 😄
            --pupil forever...------
            • mitcorbM Offline
              mitcorb
              Do my eyes deceive me?
              Does this reset the origin of the component where you please?
                sahi
                  dedmin
                  It's Christmas!!! 😍 😍 😍 😍 😍
                  • MALAISEM Offline
                    MALAISE
                    Thanks for the gift. May be could you translate or give us the file to translate Axis positionning names( it's still cyrillic written 💚 )
                    MALAISE 👍
                      sahi
                      Did I translate correctly?
                      Центра компонента>>>      Center of component>>>
                      "Центр компонента  "            "Center of component  "
                      "Низ центра компонента  "      "Bottom of center of component  "
                      "Верх центра компонента  "     "Top of center of component  "
                      "Левый дальний угол  "         "Left distant corner  "
                      "Левый ближний угол  "         "Left near corner  "
                      "Правый дальний угол  "        "Right distant corner  "
                      "Правый ближний угол  "          "Right near corner  "
                      "Центр на левой стороне   "      "Left center   "
                      "Центр на передней стороне  "    "Front center   "
                      "Центр на правой стороне         "Right center   "
                      "Центр сзади                     "Back center  "
                      axiscomp4.zip
                        marne
                        A plugin like this was overdue. Thank you so for this productivity increasing plugin. Creating lots of face me components was always annoying a bit because of centering the axis, now its fun - 👍 you're great!!!!!
                          Jim
                          Ok, now I understand! - it seemed no different than the built-in Change-axis feature. But the preset positions are nice!
                          • N Offline
                            NewOne
                            Nice tool! You might think to change the icon, because is already one in SU and this can be confusing. 😄
                              CADAddict
                              Doesn't Right clicking the axes of the component and selecting "change axes" already do what this plugin does?
                              I don't see the difference or the need for it. Anyone can enlighten me?
                              http://www.cad-addict.com/
                                This plguin adds some pre-defined axis locations, so you don't have to set the axis manually. If you know you want the axis set to the middle, bottom of the component, then this plugin will do it for you. Otherwise it could be tough to do, like in his first image example. That one would require drawing construction lines or temporary geometry in place to then align the axis to.
                                Chris
                                  Центра компонента>>> Centre du composant>>>
                                  "Центр компонента " "Centre du composant "
                                  "Низ центра компонента " "Centre Bas du composant "
                                  "Верх центра компонента " "Centre Haut du composant "
                                    In French 😉
                                        "Левый дальний угол  "         "Coin Gauche distant  "
                                        "Левый ближний угол  "         "Coin Gauche proche  "
                                        "Правый дальний угол  "        "Coin Droit distant  "
                                        "Правый ближний угол  "          "Coin Droit proche  "
                                        "Центр на левой стороне   "      "Centre Gauche   "
                                        "Центр на передней стороне  "    "Centre Face   "
                                        "Центр на правой стороне         "Centre Droit   "
                                        "Центр сзади                     "Centre Arrière  "
                                      alz
                                      Missed this one -- nice little addition! I hated having to add temporary lines to find corner snap locations 😄
                                      • jason_marantoJ Offline
                                        jason_maranto
                                        Very cool plugin -- if only someone would generate something like this that used the ease of setting axis position of this ruby combined with the align scripts function to move groups and components to each other... it's actually something I've wanted since I first started working with Sketchup but was always too afraid to try 👊
                                        Anyhow I took a stab at making a clearer english version of it and while I was trying to sort that out I decided to cobble together a context menu to make switching between them quicker...
                                        just added this stuff at the end.
                                        ` if( not file_loaded?("axiscomp.rb") )
                                        UI.add_context_menu_handler {|menu|
                                        if(Sketchup.active_model.selection[0].typename == "ComponentInstance")
                                        menu.add_separator
                                        sub=menu.add_submenu("Orient Component Axis")
                                        sub.add_item("Absolute Center") { centrcomponents1 }
                                        sub.add_item("Bottom Center") { centrcomponents2 }
                                        sub.add_item("Top Center") { centrcomponents3 }
                                        sub.add_item("North-West Corner Bottom") { centrcomponentsright1 }
                                        sub.add_item("North Side Center Bottom") { centrcomponentsrightstorona }
                                        sub.add_item("North-East Corner Bottom") { centrcomponentsright2 }
                                        sub.add_item("East Side Center Bottom") { centrcomponentsperedstorona }
                                        sub.add_item("South-East Corner Bottom") { centrcomponentsleft2 }
                                        sub.add_item("South Side Center Bottom") { centrcomponentsleftstorona }
                                        sub.add_item("South-West Corner Bottom") { centrcomponentsleft1 }
                                        sub.add_item("West Side Center Bottom") { centrcomponentszadstorona }
                                        end #if ok
                                        end`
                                        Thanks again.
                                        Best,
                                        Jason.
                                          alz
                                          I actually wanted a Center East option today and realized it wasn't there.
                                          Expanding the options shouldn't be hard, but the menu could get kinda crazy. Something like this would work:
                                          axis=menu.add_submenu("Orient Component Axis")
                                          	top=axis.add_submenu("Top")
                                          		top.add_item("Center") { function }
                                          		top.add_separator
                                          		top.add_item("North") { function }
                                          		top.add_item("North-East") { function }
                                          		top.add_item("East") { function }
                                          		top.add_item("South-East") { function }
                                          		top.add_item("South") { function }
                                          		top.add_item("South-West") { function }
                                          		top.add_item("West") { function }
                                          		top.add_item("North-West") { function }
                                          	middle=axis.add_submenu("Middle")
                                          		middle.add_item("Center") { function }
                                          		middle.add_separator
                                          		middle.add_item("North") { function }
                                          		middle.add_item("North-East") { function }
                                          		middle.add_item("East") { function }
                                          		middle.add_item("South-East") { function }
                                          		middle.add_item("South") { function }
                                          		middle.add_item("South-West") { function }
                                          		middle.add_item("West") { function }
                                          		middle.add_item("North-West") { function }
                                          	bottom=axis.add_submenu("Bottom")
                                          		bottom.add_item("Center") { function }
                                          		bottom.add_separator
                                          		bottom.add_item("North") { function }
                                          		bottom.add_item("North-East") { function }
                                          		bottom.add_item("East") { function }
                                          		bottom.add_item("South-East") { function }
                                          		bottom.add_item("South") { function }
                                          		bottom.add_item("South-West") { function }
                                          		bottom.add_item("West") { function }
                                          		bottom.add_item("North-West") { function }
                                            [attachment=0:3nck5g1d]<!-- ia0 -->axiscomp4.zip<!-- ia0 -->[/attachment:3nck5g1d]
                                            Could you post all downloads in the first post please - makes it easier to locate them.
                                            • 1 / 2
