    ATAN2(y,x) for dynamic components
    8 Posts 4 Posters 11.1k Views 4 Watching
    • M
      markozeta
      I would like to make a formal request for either an Arg(x,y) or Atan2(y,x) to be part of the built in functions for dynamic components.
      It makes life easier when you know what your angles are (positive or negative).
      BSME - Cal Poly Pomona
      Sketchup Pipe Maniac
      • J
        Jim
        Drop this in your plugins folder...
        class DCFunctionsV1
            protected
            def atan2(*a)
        	return Math;;atan2(a[0], a[1])
        Of course, all of your DC users will also need this installed...
        And... who knows what will happen if Google does decides to implement it someday.
        • M
          markozeta
          Exactly why I want it as part of Sketchup itself...
          Shrugs Oh well, thanks for the code. I'll probably end up using it as well.
          • M
            markozeta
            class DCFunctionsV1
            >     protected
            >     def atan2(a)
            >     end
            > end
            Lemme do a quick fix on that...
            class DCFunctionsV1
                protected
                def atan2(a)
            	return Math;;atan2(a[0], a[1]).radians
            sighs half an hour wasted...
            • Dan RathbunD
              Dan Rathbun
              @markozeta said:
              class DCFunctionsV1
              > >   protected
              > >   def atan2(*a)
              > >   end
              > > end
              class DCFunctionsV1
              >   protected
              >   def atan2(a)
              >   end
              > end
              You are correct for the argument, in that the DC extension always passes the function arguments as an Array (so the ***** expansion operator is not needed.)
              However, all the other trig functions do not have built-in radians to degrees conversion, and to follow convention, the internal code for the function should be as Jim showed.
              If you wish degrees from a result that returns radians, you should use the DC function degrees( *radian_arg* ), as in:
              degrees( atan2(n1,n2) )
              require('dynamiccomponents.rb')
              if defined?($dc_observers)
                # only if DC extension is active
                class DCFunctionsV1
                  protected
                  def atan2(a)
                  end #def
                end #class
              end #if
              NOTE: modifying this class no longer makes it version 1
              I'm not here much anymore.
              • Dan RathbunD
                Dan Rathbun
                See also this topic in Developers Forum:
                Custom Dynamic Component Functions = Ruby links
                • RichMorinR
                  RichMorin
                  Experimentation indicates that function arguments are passed to the Ruby method as an array of strings. So, it seems like the Ruby method should be performing coercion on the input values. (eg, a[0].to_f). Am I missing something?
                  -r
                  • Dan RathbunD
                    Dan Rathbun
                    Well, obviously the entire formula begins as one big lengthy string, is repeatedly parsed and broken up into smaller and smaller tokens, until it can build it's param arrays to pass to internal DC functions.
                    However it's not always necessary internally (DC parsing) for the params to be passed as string representations, to the DC formula method(s), if it was already necessary for the DC parser to convert the sub-string operands to a Numeric (for say, some logical comparison, in order to make a code branching decision.)
                    Exactly what they all of the mathematical DC functions do internally, just to be safe, before passing any values to methods in the Math module (or otherwise where a Numeric type is expected.)
                    IF you just have to modify the DCFunctionsV1 class, for your own use, it would only be smart, to also do .to_f() coercion.
                    Only that there are some DC functions that specifically use string args. (But we can ignore this for this issue...)
