    How cool is this...
    5 Posts 5 Posters 527 Views 5 Watching
      tomsdesk
      ...and how was it done?
      http://www.peterskirche.at/virtuelle_tour_1280x1024/Virtuelle%20tour/Peterskirche%20Zentrum.html
      2.5D Trees & Shrubs!
      • boofredlayB Offline
        boofredlay
        It was most likely created by GoCubic. All you need are 6 images. There is even a ruby script that will create those 6 images for you so you can use your SU model. I created a few in the past. Pretty slick IMO.
        http://www.panoguide.com/howto/display/gocubic.jsp
        Oh, and did I mention it was free.
        Jason has an example posted here:
        http://forums.sketchucation.com/viewtopic.php?p=91295#p91295
        Edit: You can find the ruby here:
        http://www.crai.archi.fr/RubyLibraryDepot/Ruby/en_cam_page.htm
        • pbacotP Offline
          Yes I often wonder just how they can build those incredible buildings... or do you mean the VR?
          did you "look" straight down? http://www.photoartkalmar.com/Photoart-Kalmar%20Flash/QTVR/index.html
          this is an Apple QT VR FWIW.
            And a little experiment I made with SU and Kerky (not an excellent render however) 😳
            http://www.gaieus.hu/su/videos/Carmelite.mov
            • Paul RussamP Offline
              Paul Russam
              This is one I did a while ago. It has 40+ hotspots and was a complete pig to setup.
              I used the CubicPanOut plug-in to produce the 6 views per hotspot then moved the 40x6 images over to my Mac and then CubicConverter and CubicConnector to make the finished movie.
              This is a link to the Quicktime movie on my dropbox account, its 280Mb so don't try and play it from here, you'll have to download it first.
              http://dl.getdropbox.com/u/373226/StPeters/1287-QTVR-V2.mov
              Paul Russam
              English doesn't borrow from other languages. It follows them down dark allies, knocks them over, and goes through their pockets for loose grammar.
