Turntable animation
i am trying to do a simple turntable animation in 72 Frames. (Webexporter does that automatically but has a poor image resolution).
i tried a plugin "Proper Animation" but this only rotated my objekt in sketchup. Export animation did not work and i can not set the Frames and then it would be too fast in movement.thank you
marco
Have you seen the button "options" in export options? I don't see why it shouldn't work. Unfortunately, you can not set the animation length there. So if you want for example 12s of animation, that makes 72/12=6 frames per second. Then go to each scene's properties and set the time so that the complete duration will be 12s. You can also set the resolution.
If you export jpeg images, the speed is ful in your hands and you can put the animation together in another program.There's also a large amount of different ways to get customized results. See this thread.
I hope that helps.
[blatant plug]
If you fancy doing it the old fashioned way, this tutorial covers the basic method: http://www.sketchucation.com/animating-an-object-in-google-sketchup/
[/blatant plug]
Register LoginAdvertisement
