    [Plugin] Drape Cpoints
    46 Posts 23 Posters 47.4k Views 23 Watching
      thepolarblair
      Hi TIG - First off - Amazing Plugin! Currently trying to model a leather headboard and will be using it to get nice uneven edges for a more realistic look. This may have already been flagged up so please ignore if that's the case, but I can't seem to get the plugin to work in Sketchup 8. 6 is fine so its not causing me any hassle but I just thought it could be worth a mention. Again - thank you very much. I'll try to post the results when I get there.
      • TIGT Online
        It should work fine in v8.
        Do you have the latest v8M3 installed ?
        Do you get any error messages in the pre-opened Ruby Console when you run this tool ?
        Do you have a 'rogue' script auto-loading that can cause issues by messing with the base-classes or making ill-formed observers ?
        Examples are SketchyPhysics, Matchbox, DrivingDimensions and an old SolarStudy tool [I forget its exact name]...
        If so, try moving them out of the Plugins folder and retry the tool...
          anar
          Great plugin thanks TIG!
          But why not let the user choose his own projection axis instead of only using Z down ?
          It would make the plug even more useful if you don't have to rotate the target group as intended before to use it.
          Cheers!
          • olisheaO Offline
            olishea
            still one of my all time favourite plugins
            oli
              dkdude
              Hey guys, is there an update versions of "Drape Cpoints", and "Triangulate Points"? thx!
              • TIGT Online
                Why do you need an update ?
                The current versions should work...
                • 3 / 3
