Multiple Action Callbacks?
The docs don't say you can do this, but in my first test, it worked. Anybody using this in production code?
# selectionInfo.rb require 'sketchup.rb' # Create the WebDialog instance wd = UI;;WebDialog.new("Selection Info", false, "Selection Info", 200, 200, 200, 200, true) # Attach an action callback wd.add_action_callback("refresh") do | js_wd, ignored_param | total_selected = Sketchup.active_model.selection.length script = "rubyReturned("+ total_selected.to_s + ")" js_wd.execute_script( script ) end wd.add_action_callback("lie") do | js_wd, ignored_param | js_wd.execute_script( "rubyReturned( 'A million' )" ) end # Find and show our html file wd.set_file( 'c;/models/rubies/selectionInfo.html' ) wd.show()You'll need to change that hard-wired path to your own.
<!-- selectionInfo.html --> <html> <head> <script> function rubyCalled( nop ) { query = 'skp;refresh@' + nop; window.location.href = query; } function rubyLies( nop ) { query = 'skp;lie@' + nop; window.location.href = query } function rubyReturned( value ) { var message = value + " items selected."; document.getElementById('output').innerHTML = message; } </script> </head> <body onload='rubyCalled("refresh")'> <div align=center> <h3 id="output"> </h3> <button onclick="rubyCalled('this_is_ignored')">Refresh</button> <button onclick="rubyLies('this_too_is_ignored')">Tell Lie</button> </div> </body> </html>(Thank you, Scott Lininger, for the original code.)
I was not aware of any limitation on the number of callbacks. Out of curiosity, where did you read that?
I had assumed that you needed a switch in "the" action callback for various options. Didn't know that the "get_data" part of 'skp:get_data@'... from Scott's how-to was a variable.
And where does one report that the invaluable link to Scott's article in the doc is simple text, not a link?
One technique I have used is to pass the name of the Ruby callback to the Javascript. In many cases, you can use a single Javascript function to call any number of Ruby callbacks.
function callRuby(callback_name, parameters) { window.location="skp;"+callback_name+"@"+paramters; } <input type="button" onclick="callRuby('draw_square', 10);" value="Draw a Square"> -
Neat trick, and that tells me exactly what I wanted to know. Now where to we go to get the docs to say "add one or more callbacks ..."?
Register LoginAdvertisement
