    Multiple Action Callbacks?
    5 Posts 2 Posters 478 Views 2 Watching
      MartinRinehart
      The docs don't say you can do this, but in my first test, it worked. Anybody using this in production code?
      # selectionInfo.rb
      require 'sketchup.rb'
      # Create the WebDialog instance
      wd = UI;;WebDialog.new("Selection Info", false, "Selection Info", 200, 200, 200, 200, true)
      # Attach an action callback
      wd.add_action_callback("refresh") do | js_wd, ignored_param |
      	total_selected = Sketchup.active_model.selection.length
      	script = "rubyReturned("+ total_selected.to_s + ")"
      	js_wd.execute_script( script )
      wd.add_action_callback("lie") do | js_wd, ignored_param |
      	js_wd.execute_script( "rubyReturned( 'A million' )" )
      # Find and show our html file
      wd.set_file( 'c;/models/rubies/selectionInfo.html' )
      wd.show()
      You'll need to change that hard-wired path to your own.
      <!-- selectionInfo.html -->
      <html> <head> <script>
      function rubyCalled( nop ) {
      	query = 'skp;refresh@' + nop;
      	window.location.href = query;
      function rubyLies( nop ) {
      	query = 'skp;lie@' + nop;
      function rubyReturned( value ) {
      	var message = value + " items selected.";
      	document.getElementById('output').innerHTML = message;
      </script> </head>
      <body onload='rubyCalled("refresh")'>
      <div align=center> <h3 id="output"> </h3>
      <button onclick="rubyCalled('this_is_ignored')">Refresh</button>
      <button onclick="rubyLies('this_too_is_ignored')">Tell Lie</button> </div>
      </body> </html>
      (Thank you, Scott Lininger, for the original code.)
        Jim
        I was not aware of any limitation on the number of callbacks. Out of curiosity, where did you read that?
          MartinRinehart
          I had assumed that you needed a switch in "the" action callback for various options. Didn't know that the "get_data" part of 'skp:get_data@'... from Scott's how-to was a variable.
          And where does one report that the invaluable link to Scott's article in the doc is simple text, not a link?
            Jim
            One technique I have used is to pass the name of the Ruby callback to the Javascript. In many cases, you can use a single Javascript function to call any number of Ruby callbacks.
            function callRuby(callback_name, parameters) {
              window.location="skp;"+callback_name+"@"+paramters;
            <input type="button" onclick="callRuby('draw_square', 10);" value="Draw a Square">
              MartinRinehart
              Neat trick, and that tells me exactly what I wanted to know. Now where to we go to get the docs to say "add one or more callbacks ..."?
