    Extending ComponentInstance Class
    9 Posts 5 Posters 616 Views 5 Watching
    • F Offline
      fizgig
      I want to add a new method to the ComponentInstance class. Not sure if it's possible. Here's the basic idea:
      class ComponentInstance
      	def yo
      		UI.messagebox("Tada!")
      end #class ComponentInstance
      I then have try to call the "yo" method on a component instance later and it says the method yo is undeclared.
      Am I missing something?
      • Chris FullmerC Offline
        Change it to this and it will work:
        class Sketchup;;ComponentInstance
           def yo
        You need to specify that the ComponentInstance class is a subclass of the Sketchup class. (did I get my terminology right?)
        Chris
        All my Plugins I've written
        • fredo6F Offline
          fredo6
          Chris
          Actually "ComponentInstance is a class of the Sketchup module"
          to fizgig
          It is not a good practice to subclass a built-in class, whether Ruby or Sketchup. This could generate clashes between scripts and conflicts in names. Just imagine I do the same, and my script is loaded after yours, then it would be my version prevailing, and your script would not work!
          The best is that you write a method within your namespace (module or class):
          module Mymodule
          def Mymodule.comp_yo(comp)
          end  #module Mymodule
          Fredo
          • AdamBA Offline
            AdamB
            I'm sure what Fredo meant to say is that its not good practice to overload (or to some degree) extend a built-in class. Its very good practice to derive from / subclass an existing class to create a specialization you may want.
            Adam
            • F Offline
              fizgig
              Understand the concerns. On the way home from work I figured out a way to not have to take this approach but it's good to understand what's going on. Thanks!
                Adam
                It's the potential that multiple plugin authors might extend a base class and create conflict.
                • AdamBA Offline
                  AdamB
                  Hence my point that extending a class has the potential of conflict. Deriving a new class does not.
                    Ah. Sorry, my bad. Mis-read that.
                    • fredo6F Offline
                      fredo6
                      Adam
                      Thanks Adam, this is exactly what I meant.
                      Somehow, the best would be that we restrict the possibility of name clashing only at Module level, which implies that all scripts are alway encapsulated within modules, so that it is easier to control.
