    DC - Fence issues
    5 Posts 2 Posters 1.7k Views 2 Watching
    • utilerU
      utiler
      Hi guys.
      I started playing with DC's during beta but never really followed through with it so I'm a little rusty.
      Attached is a simple picket fence. I want to scale it in only one direction so I've set it up as per the user guide tutorial [expect in metric.]
      A few questions:
      1. Why is it when I scale, it doesn't scale the component right the my selection point? For some reason it scales it about 2/3 of the way along the scale ration....
      2. I want to add a fence post at 2700mm increments maximum, any ideas on how to do so? I assume I +COPY* somehow but not sure how to leave a gap in the palings for the post....
      3. Also, If the length of run does not divide exactly into 2700 [an no doubt it won't], how is it set up to do so?
      Fence1800-DC.skp
      Just Curious...
      • J
        Jim
        Andrew,
        I got it scale correctly by setting the LenX of the top and bottom rails to the length of their parent minus the length of the Post; so..
        LenX for the top & bottom rails: =Fence1800DC!LenX-FencePost!LenX
        I don't have any good explanation of why it needs to be done this way. To me it seems like it should work without explicitly setting the rail LenX's.
        • utilerU
          utiler
          thanks a lot Jim, that makes sense and seems to work.....
          How about copying a post into the fence at say 2700 maximum centres?
          πŸ‘
          Just Curious...
          • J
            Jim
            I found this example by Google that might be worth a look:
            http://sketchup.google.com/3dwarehouse/details?mid=65ca6ec72a98e043de650492e45fb14f
            It's more complicated than it needs to be because there are 4 styles of fence in the Component, but the idea is the same as yours.
            • utilerU
              utiler
              Thanks heaps Jim, I will be sure to have a look tonight. πŸ˜‰
              Just Curious...
