    Organising Rubies
    9 Posts 5 Posters 793 Views 5 Watching
    • K Offline
      Khai
      I've noticed that some rubies install into their own submenu in the plugins dropdown.. is this something we can do to organise the plugins? eg put all the edge tools in 1 submenu, all the exporters in another etc?
      just a thought..
        remus
        This plugin makes an attempt at doing that: http://www.smustard.com/script/Organizer
        Although it isnt compatible with all plugins.
        • K Offline
          Khai
          aah thank you
          • Chris FullmerC Offline
            You can also do it yourself to a certain extent. The main problem is with the scripts that are encrypted so you can't edit them yourself. And I think Rick's script that Remus linked to is also limited by that same issue as well?
            Chris
            All my Plugins I've written
              Jim
              I was working on cleaning up and consolidating my own plugin mess earlier today, as a matter of fact. I hope to get all mine into a single sub-menu, along with some help and configuration items for each of them.
              • K Offline
                Khai
                how would I edit the ruby to move into a submenu then? (totally in the dark on this)
                  RickW
                  The challenge then becomes trying to remember who wrote that cool plugin that will do what you need. 😄
                  I think we developers need to get on the same page, whatever that ends up being.
                  RickW
                  www.smustard.com
                    RickW
                    Only to the extent that if the original author didn't make it Organizer-compatible, it won't show up in submenus. Organizer can still load an "organized" .rbs file, but it will show up in the hard-coded menu, and OrganizerEdit (obviously) can't edit it to make it compatible.
                    RickW
                    www.smustard.com
                      Jim
                      I have been working at making my plugins compatible. Although Organizer is not a free script, I want to support my users who do use it. Particulary for single-file scripts, it's as easy as:
                      ($submenu || UI.menu('Plugins')).add_item("Menu Text") { command }
                      And yes it does work if the script is scrambled.
