    Component name
    3 Posts 2 Posters 384 Views 2 Watching
    • honoluludesktopH Offline
      honoluludesktop
      I would like to patch this plugin to export the currently selected component as a DXF file with the same name as the selected component. The plugin currently exports the DXF file using the model name. If more then one component is selected, the first component name is OK. Can anyone show me how to add that into the following:
      def dxf_export_mesh_file
            model = Sketchup.active_model
            model_filename = File.basename(model.path)
            if( model_filename == "" )
              model_filename = "model"
            ss = model.selection
              #exported file name
               out_name = UI.savepanel( file_type+" file location", "." , "#{File.basename(model.path).split(".")[0]}." +file_type )
               $mesh_file = File.new( out_name , "w" )
               model_name = model_filename.split(".")[0]
               dxf_header(dxf_option,model_name)
        ### untested
        path = File.dirname(model.path)+"\\"
        out_name = model.title + ".dxf" ### as default
        ss.each{|e|
          if e.class == Sketchup;;ComponentInstance
            out_name = e.definition.name + ".dxf"
            break ### exits after it finds one
          end#if
        out_path = path + out_name
        ### etc ### model.export(out_path,false)... ???
          honoluludesktop
          Thanks, I will see if I can make the plugin work πŸ™‚
