    Dimension problem
    7 Posts 3 Posters 1.2k Views 3 Watching
    • B
      bravoddb
      I did a model, but at the time I want to place dimensions, they (dimensions) don't appear, why? what can I do? I have the layer turned on. what else could cause this problem?
      • Chris FullmerC
        Under the "View" menu, make sure that you have "guides" turned on. See if that helps,
        Chris
        All my Plugins I've written
        • B
          bravoddb
          No they don't appear, what else could be?
          This s the second model I made and have the same problem, but when I just started a model they appear, why?
          • SketchUp Guide TommyS
            Hi bravoddb,
            I saw a report of this last week. As you mention, the issue does appear to be model specific.
            What happens if you copy and paste the geometry into a new SketchUp file?
            Regards,
            SGT
            • B
              bravoddb
              Thanks, I think doing what said fixes the problem. But How canI avoid it?
              Thanks a lot.
              Bravoddb
                Hi Bravoddb,
                Since copy and pasting the geometry into a new file resolves the issue, it sounds like a "corrupt camera data" problem. This use to be somewhat common in older versions of SketchUp.
                I'm going to keep investigating on my end, and I'll let you know if I have any updates.
                Regards,
                Tommy
                Regards,
                SGT
                • Chris FullmerC
                  do you have a bad model that could be uploaded here to look at? I'd like to see the corrupt camera πŸ˜„
                  Chris
