    Copy along path with correct alignment
    5 Posts 4 Posters 947 Views 4 Watching
    • K
      Kenny
      I use 'copy along a path' for objects such as trees where it doesn't really matter how they are orientated. If however you have a horizontal object such as a hedge it's important that it is aligned parallel to the path. The attached image shows what I mean. The top result is the desired one, the bottom is the actual result when you use copy along a path. The other issue is that if the component has been rescaled, copy along a path uses the original size.
      I'd be grateful if anyone knows of a plug-in that will achieve the top desired result? Failing that is it possible for one to be written? This would be a real time saver if it could be achieved.
      http://www.townscapesolutions.co.uk/
      • D
        dylan
        I have had varying results, depending on where I set the axis of the component to copy.
        http://dmdarchitecture.co.uk/
        • simon le bonS
          simon le bon
          Hi Kenny,
          I think you will find a good solution in using bending processes with these great plugins which are ChrisFullmer's ShapeBender and Fredo's FredoScale
          PathCopy v.2.100 by Rick Wilson can be very interesting as you can see in these following links:
          Copying Along A Path
          Dylan's 😉 Cycle Bridge WIP
          Copy along a path plugin
          But you before need to hardly tame its wilde behavior 😕 !!!
          😎 simon
            The trick with Copy Along Path is to set the axes So the red axes will align with the path. In the case of the hedge component, make sure the the red axis is aligned with the long dimension and if you want it to straddle the path, put the origin half way between front and back edge.
            • K
              Kenny
              Thanks for the suggestions and links everyone. I'll try them out when I have more time.
              Kenny
