    3 Skeng pipe plugin
    3 Posts 3 Posters 4.4k Views 3 Watching
    • A
      Andre Potgieter
      Hi everyone
      Please help!! I am new to the forum, and need some assistance.
      I downloaded the 3skeng Pipe: 1.0.004
      plugin, it worked brilliantly and but then suddenly the round pipes turned into octagons.
      Cheers Andre
      • GaieusG
        Hi Andre,
        I don't know the plugin but what I guess is that it creates a follow me operation and in this case with a circle of 8 segments (note that circles in SketchUp are all segmented).
        Anyway, a certain "feature" of the Follow me tool in SU is that it explodes curves (and circles) so what I guess, this is what happened here.
        You can select all of the piping > Right click > Smooth/Soften edges and push the slider in the dialog popping up to the right until your tubes become smooth again.
        If this is not the problem,post a file or something so that we can have a look.
        • S
          SHK
          Could you fix the problem? You can define the number of segments the first time you use the Pipe tool.
          The new release on http://www.3skeng.com has a settings menue with the possiblility to define the number of segments.
          Regards, Sebastian
