    New Sketchup Artist webpage
    18 Posts 9 Posters 2.0k Views 9 Watching
      majid
      hi everyone 😄.
      this is just to inform you , that Sketchup Artist webpage has been updated with new appearance and materials. also they have generously dedicated a page to one of my tuts ( about better render with podium + PS). here is the home page :
      http://www.sketchupartists.org/
      and this is my tut ( that also could be done using KT):
      http://www.sketchupartists.org/?page_id=2754
      cheers
        sepo
        Hi Majid
        Thanks for promoting Podium on the blog. I am slightly surprised with some claims in the tut and especially statement about new preset. Without going into argument I will just say you should state you are using GI only . GI does not show leaks . They sometimes appear when using other sources of light in conjuction with camera position. Now if you say otherwise could you send me that preset for me to inspect. BTW for the record I have written most of the presets for Podium 1.6 and 1.7 .
          majid
          dear Sepo, I just twaeked one of presets.. and here it is:
          plz unzip it
          if you e-mail me at : majid _ yeganegi (at) yahoo dot com, I can share you some Ideas too 😉
            d12dozr
            Thanks Majid...this is an excellent resource! 👍
            http://goo.gl/f7ooYh
              sepo
              I have now inspected your preset and tested it. To be honest I was secretly hoping that you found something that I missed in hours of (days) testing and tweaking.
              I am afraid it did not perform well at all. It is slower than all of our presets and it is showing same or more "leaks". Now without going into depth of it, adding higher AA and throwing larger number of rays is not right way forward. 😉
              I took scene which has shown leaks in past and tested it with 3 presets. The scene, on purpose, have some reversed faces and all test were done with same lighting and same settings both AA and quality at 100%. The scene was tested on the same old duo computer and all renders were rendered to size of 1024X768. AllRenders shown are raw.
              The first render is with your preset. It took longest time to render. It took 7 min. and 17sec.
              The second render was done with our Default preset. It took 4min. and 23 second.
              Our default was faster for 40% and it showed similar number of leaks and in less prominent position.
              The third test is with preset I have been working on for some time. It is leak proof but sometimes has other problem and it is not ready for release.
              It rendered in 7min and 1 sec, which was slightly faster than yours.
              As I said before no preset shows leaks when rendered with GI only ever.
              On the other note in your tut you seem to appropriate my way of rendering clay together with Zem’s way. It would have been nice if you acknowledged that in your tut somehow.
              Anyway, thanks for showing an interest in Podium and if you have some ideas you can always email me or contact me on the Podium forum. As I said before please do not take this wrong way .
              Cheers
              rendered with Majid's preset
              rendered with Podium Default preset
              rendered with beta X preset
                majid
                thanx dear Sepo , for reply and informing me 😄
                my aim was finer edge and shadow , so started from a preset called "default ultrafine shadow" from podium forum , and also tweaked it to have softer shadows and better edges (photon number and AA ) and as u may observe the result it reaches the aim. (less dark dots at shadows and also softer edges than default preset- that is obvoius at renders above)
                also your X beta rocks!!!! very nice shadows and soft edges with no leaks 😄 congrats.
                and it would be nice if you test this one plz :
                tweakin ambient
                about the e-mail, I've tried to PM you from the podium forum , but it doesnt let me ( as a noob i guess), BTW the Idea i was going to share is easy and maybe you've rached it befor, it is : adding an slider beside each light so that easily it could be adjusted.
                I mean using DC in su 7 we could add an slider ( that is linked to the emitter group inside the light component) so that when we change the slider , the size of emiter group is changed while the group is hide and also the slider itself is hide and we could reach it just using DC tool, so that it prevents confusing the scene). also the slider can shows the light power in Watts i.e. ....and the light color....
                by now you are adding a fake part , a bit far from real light source that is not correct , and is a bit confusing , and i think my idea maybe results better realastic lights.
                yours majid
                  sepo
                  No problem mate.... you can email me to sepo100 at googlemail dot com. I will try your AO...I have AO preset version myself as well so maybe there is something I can learn from yours.
                  If you have sample of your DC which works it would be great.
                    majid
                    dear Sepo I am nither an KT master nor Podium, but this AO is for a while ago (I think I borrowed it from KT presets), none of KT biased preset are free from leaks (except if have solid models - not just a face ).
                    about the DC , that is just an idea , but it's raw start could be found maybe here :
                    http://forums.sketchucation.com/viewtopic.php?f=80&t=20363
                    I've replaced the group geometry with only some dots, that prevents confusing geometry... maybe it can inspires you, mate 😄
                    yours majid
                      linea
                      majid
                      I really like the sketchup artists site. Well done.
                        majid
                        Dear James your job is respectable,also Sepo is right , but I was not aware from other, similar jobs , that were done by him and also Zem. then I explained, and Sepo accepted verry friendly.(thanx to him),also even I asked him to give links to those tips, and it would be nice if he gives linkes 😄
                        I like our friendly forum, it is great place
                          marked001
                          great job Mateo & James.... looks great!!
                          http://www.revision21vis.com
                          instagram: revi21on
                            majid
                            I'm here to thank again from Mateo & James for their great job and also inform you about my new mini tut , there: http://www.sketchupartists.org/?page_id=2981
                            hope you like it ( thank James for editing) 😄
                            • H Offline
                              hayati1350
                              سسلام جناب آقای یگانگی
                              این ساایت بخش فارسی ندره؟
                                majid
                                سلام. واستون پی-ام گذاشتم
                                موفق باشید
                                  shabnavard
                                  جناب یگانگی من وقتی با یوزرنیم وارد بخش فارسی خرد انجمن میشم میگه شما اجازه برای این قسمت را ندارید
                                    doman2012
                                    salam
                                    man nemetonam bakhshe farsir peyda konam chera
                                    • H Offline
                                      hoyateh
                                      سلام آقای مهندس یگانگی
                                      من به تازگی و به پیشنهاد یکی از دوستانم عضو این سایت شدم. اینطور که به من گفتن شما یک فوروم فارسی در این سایت راه‌اندازی کردین. اما من نتونستم پیداش کنم. ممکنه راهنمایی کنید
                                      ممنونم
                                        majid
                                        سلام به همه دوستان فارسی زبان
                                        ببخشید، دیر دیدم
                                        همواره میتونید بهم پیام بدید یا با شمارم تماس بگیرید
                                        به سایت راندو دات آی-آر هم میتونید سر بزنید، تقریبا تمام دوستان باتجربه اینجا که ایرانی هستند اونجا هم هستند و اطلاعات رو تبادل میکنند. اون سایت بخاطر محدودیتهای ما در بحث کپی رایت در اینجا راه اندازی شد و لذا محدودیتی نداره
                                        با اینحال درصورتی که مایلید همواره به روزترین اخبار رو داشته باشید، اینجا محل صحیحه
                                        اما در مورد گره فارسی. پس از ثبت نام به بخش یوزر کنترل پنلتون وارد بشید و در بخش یوزر گروپس، گروه فارسی رو انتخاب کنید. به اینترتیب این گروه برای شما قابل دسترس خواهد بود
                                        همواره موفق باشید
