    Commercials - how
    5 Posts 4 Posters 456 Views 4 Watching
    • J
      Jorgensen
      Does anyonw in here know which programs are often used by commercials ?
      The commercials I have in mind are thoes small clips in TV, where text pops up, and slowly gets bigger or moved and effects like that.
      Could one of them be Adobe After Effects ?
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
      • soloS
        solo
        http://www.toonboom.com/main/
        http://www.solos-art.com
        • EarthMoverE
          EarthMover
          After effects is used for compositing and effects and is probably used in commercial production quite a bit. The actual 3D text animation is probably done in a program like 3ds Max, Maya or Cinema 4D. Lower priced programs could also do it...such as Xara 3D, Adobe Flash, or Blender.
          Content Creator at Skapeup
          • J
            Jorgensen
            Hi Earthmover and Solo
            Thanks both for your input. Hmm toonboom is looking alot like Flash...
            • Alan FraserA
              Alan Fraser
              If you just want to put text effects over still images or maybe a slideshow with various transitions effects, rather than actual movie footage, you could consider something like Swish...Flash without the pain. The effects can be quite sophisticated and virtually drag and drop. You could then export as avi and splice into whatever animation you already have.
              http://www.swishzone.com/index.php?area=products&product=max&tab=demos
              3D Figures
