    Add hidden layer
    8 Posts 3 Posters 803 Views 3 Watching
      Jorgensen
      When I create different models to analyze, I often use the script "add_hidden_layer.rb" by Jim Foltz to add a layer that is hidden in already created scenes, and then add a scene like 05, where layer 05 is shown.
      I would be greate if the scene (same name as the added layer e.g. 10) was added automatic - is this possible in ruby ?
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        Jorgensen
        ok, I figured it out to automatic add a new scene with the same name as the layer
        page = model.pages.add newname
        But how do I turn all the other layers off, except the one just added, in this new scene ?
          remus
          Something like this should turn of all the other layers (untested, btw.)
          Sketchup.active_model.layers.each {|layer|
          unless layer.name == "newname"
          layer.visible = false
            Jorgensen
            Hi Remus
            Does it turn off the other layers in the new created scene (page) - or is it in generel ?
            What I need is, when I press the new scene, the only layer that is visible, is the one with the same name as the scene.
            I hope that I'm describe it ok
              Jorgensen
              Hmm, well I know how to add the page, but it 'remembers' everyting, I need it to only remember layers - is that possible ?
              It might be simple, but I'm a total newbie πŸ˜•
                remus
                Sorry, i didnt really read your post properly. The snippet i posted will hide all the layers except the named one. Not sure how youd get it to apply that to your scene, though.
                  Try this: http://forums.sketchucation.com/viewtopic.php?p=345385#p345385
                  [EDIT; AddPage.rb has been moved to its own thread...]
                    Jorgensen
                    @TIG
                    Thanks for your input, even though I couldn't understand your script 😳
                    But I managed to get it to work by using this:
                    layers.each { |l| page.set_visibility(l, false)}
                    page.set_visibility(layer, true)
                    puts page.update(32)
                    page.use_axes			= false
                    page.use_camera		= false
                    page.use_hidden		= false
                    page.use_hidden_layers	= true
                    page.use_rendering_options	= false
                    page.use_section_planes	= false
                    page.use_shadow_info		= false
                    page.use_style			= false
                    It might not be beautifull, but it works πŸ˜„
