    Blacksmith shop (Final render)
    8 Posts 4 Posters 815 Views 4 Watching
    • artysmediaA Offline
      artysmedia
      http://farm3.static.flickr.com/2599/3729002568_826a9586c6_o.jpg
      Working with: Win7 64 bit OS - Core i5 - 2,27GHz and 8GB RAM
      Blog: Artysmedia
        Hi Roberto,
        I love your posts but what are they used for? Is it for a game? Also where do you source your textures from?
        rgds,
        Rich
          smokinbakin
          How did you achieve that final render?
          "Set your goals low, and hope you don't get lower"
            artysmedia
            I put my sketchup models in the 3d studio Max program and rendered with V-Ray.
            After that, i play a little with Photoshop πŸ˜‰
            Blog: Artysmedia
            • W Offline
              Walter S. Arnold
              No chimney? Where is his forge?
              Is he a toolsmith, a weapon maker, or a farrier? It's important to know whether he is tempering the steel or just forging it.
              If he is tempering, he needs to control the light where they are working, to see the temper of the steel. Most blacksmith shops I've been in have been dim, just one or two small windows, not open areas that the sun can get in.
              Look through the Abana site, http://www.abana.org/
              They might have some shots of contemporary blacksmiths shops, the layout and tooling won't be much different from medieval ones. (except the new ones have drop hammers and fancier anvils, and some use gas forges)
              It also seems larger than necessary, unless he's making weapons and needs to keep them locked up inside. And the grounds are too clean, there should be lots of scrap metal, half-finished projects, old benches, and other junk piled up outside.
                artysmedia
                No of the buildings that I have done until now has chimney, still...
                Sorry, 😞 it is only a building.
                Blog: Artysmedia
                  artysmedia
                  Hi Roberto,
                  rgds,
                  Rich
                  The models are to make a little city, and now (to texture the castle) i use a lot flickr to search photos of ancient buildings, so the textures are not mine...
                  http://farm4.static.flickr.com/3514/3728199557_d8244d2d24_o.jpg
                  Blog: Artysmedia
                    artysmedia
                    http://farm4.static.flickr.com/3464/3728749293_77baa9708e_o.jpg
                    Blog: Artysmedia
