    Bezierspline
    4 Posts 3 Posters 485 Views 3 Watching
      JALLAO
      I have downloaed bezierspline into Sketchup 7 (Plugins file) on a Windows XP home platform. I have been unable to access the ruby. It doesn't appear in DRAW or PREFERENCES-EXTENSION. I believe I have followed the instructions and have successfully downloaded other Ruby's. Has anyone else had a problem or can make a suggestion to implement this.
        Do you have bezierspline.rb and a folder called BZ_Dir_12 in the Plugins folder?
          JALLAO
          Yes both files are present.
            Daniel S
            Download again the plugin from here:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=13563
            and read the important note before install (You should delete any BZ__***.rb files that existing the Plugins folder. You should also delete the folder BZ_Dir.).
            Daniel S
