    Lightup noob questions
    extensions
    5 Posts 2 Posters 939 Views 2 Watching
    • V
      vizier
      How do I reset everything? I seem to have set some materials to emitter status then forgotten which ones. I just want to start over.
      Also my point lights dont seem to do anything. THe emiitter works "ok" but the point lights never emit light. Any ideas?
      • AdamBA
        AdamB
        You can choose the menu item Tools->LightUp->Remove All LightUp Info to strip all LU markup from your model.
        If you hover over the PointLightSource with the Query tool, does it show the radius of light and a tooltip showing the lux power? If so, perhaps its just not powerful enough. LightUp uses physical units for lights so you'll need to ensure you don't have a 60 watt bulb in a room a mile wide etc.
        Adam
        • V
          vizier
          I lost the post but thanks for this info!
          I tried jacking up the lumines(?) of the bulb exponentially but as far as I can tell they just are not "on". This is highly annoying for obvious reasons. Maybe the component im using is broke / wrong? Where can I get a known good point light component?
          • AdamBA
            AdamB
            If you open a new Sketchup document, LightUp automatically adds a new (good) Component Definition for PointLightSource. So open the Component Browser and you'll see it there.
            Adam
            • V
              vizier
              Im still having a lot of problems with light up.
              -Lightup changes the colors of a lot of my textures
              -Lightup seems to have problems rendering some of my components, some houses have transparent roofs, some entire buildings are missing. As soon as I turn off light up everything looks fine again.
              -I still cant make the points light work in my city. Do they have to be a part of the components them selves or can they just be free floating??
